True, but with all due respects, you can never factor in the randomness of karma... Under normal circumstances it could be assumed that the chassis is strong enough to withstand that force, but in an accident the integrity might have been compromised, and whilst the cable my stand up to the force, a damaged weld, or stressed rivets could let go. What I found interesting to see was whilst a thick covered cable / chain was used at the damaged train, there was a fair amount of stretch in whatever cable was used between the 59 and the damaged coach.
I respect that there were pressures to remove the debris as quick as possible, and there was probably no alternative but to use one or two locos to pull the debris out of the tunnel, but it would seem from the replies here that most of us feel the guys in the video should have been further back.
