Class 158/159 recovery following Salisbury collision
reddragon
24 Mar 2016
Churn (closed)
Using the nylon strap seems a little "elastic" to me but I guess heavy duty chains are no longer HASAW approved. Seeing 59003 bounce on the end of the strap is a little unnerving but the guys on the ground are professionals and know what they are doing.
When I did serious off roading in Land Rovers a long elastic rope was used for recovery. It gave you both traction and momentum of the mass of the recovery vehicle to pull things out. I am surprised that they didn't give the 59 more of a run up at it but I suppose being around if the rope snapped! A small rope snapping and hitting a Land Rover was messy enough :rolleyes:
alxndr
3 Apr 2015
The wheelmarks dug into the track from the 59 on the second video are horrific.
It's a joke—they're not from this incident. Not even the same country by the looks of things.
Peter Mugridge
8 Apr 2010
Epsom
I suspect that those wheelmarks are from another video and added for effect. I am sure I have seen that image before - from the USA
I haven't seen the bit you are all talking about because it has been deleted, but from the way you're all talking about it... is it the famous image of rails almost completely worn through with spin?
Crossover
4 Jun 2009
I did wonder why they used a train to pull another out of some wreckage rather than a crane or something
I would presume because it is pretty inaccessible for a crane and lifting it could damage the tunnel roof. Once it is out of the tunnel, life will be, at a guess, a lot easier
hwl
5 Feb 2012
yep
Ash Bridge
17 Mar 2014
Stockport
There was a comment on Twitter suggesting that the class 59 had its creep-control disabled during this rescue attempt for fear that due to the extra traction there was a risk that the chains/ropes likely would have snapped had it been enabled, could anyone more knowledgeable advise on this please?
Llanigraham
23 Mar 2013
Powys
They are using a Kinetic Recovery Rope, which is designed to stretch and then shrink, thereby providing additional "pull". They are also safer if they get overloaded and break. Very common in many recovery situations nowadays.
Trackman
28 Feb 2013
Lewisham
Given where it is (ie next to the welfare prefab and within the cordon, the owner/staff member is wearing a hi viz) it'll have been rented specifically for the staff.
It's FW catering, I've seen a Fish and Chips van on the railways too.
Going back on topic, I would have thought they would have winched it out with some massive land anchors or something.
Possible in this situation if you use too much force it could damage the tunnel lining.
RPI
6 Dec 2010
I belive the second vehicle has now been craned out
FOCTOC
23 Jun 2018
No, that is wibble.
Trackman
28 Feb 2013
Lewisham
Just read on Twitter they seemed to have moved the wedged unit, if it's clear or not is a different story.
The recovery is continuing today with the removal of more train carriages. As you can see we’ve had a real challenge dragging this one from the tunnel, but after several attempts it finally budged.
VEP3417
27 Jun 2011
Hampshire
i did wonder about the elastic tow line but hadnt considered it might be better than a solid chain, as someone has said that could have snapped and most likely flung back into the 59 or in a random direction and looking at photos there is a group of workers quite near by
i suppose when we think of recovery we just think of brute force and a metal chain :lol:
Towers
30 Aug 2021
I see the injury claims have started...
Screenshot from the Salisbury Journal page linked above:
(Image is a screenshot from the Salisbury Journal website page previously linked to up-thread, with text: Two Salisbury train crash victims are pursuing a personal injury claim. One of the Fieldfisher serious injury solicitors representing them, Jill Greenfield, said: "It may be that psychological injuries are much more serious for people trapped on a train thinking they might die.” )
Gloster
4 Sep 2020
Up the creek
In the 1980s a Class 47 ran down an embankment and was recovered by quite a collection of its class mates, and a clever arrangement of steel cables. Was it 47 522 at Forteviot in July 1982?
On 31 October 1977 31 273 went through the end of the loop at Hanwell and down the embankment. It took six Class 47, including two on the Relief Lines to prevent them being pulled out of alignment, and a lot of Kelbus gear to get it back on the track.
EDIT: googling Kelbus gear and choosing images finds some photos.
The local paper reported (at 1316) that it was craned out earlier this afternoon. Network Rail have since posted (at 1628) a photo of the 159 middle car on a low loader. Can’t link to the exact Twitter post, sorry.
NR also posted the third car is now ready to lift, presumably in daylight tomorrow morning.
reddragon
24 Mar 2016
Churn (closed)
Rear coach of the 158 is visible here, presumably the next lift tomorrow morning:
It looks very much as though it was stopped by the tunnel portal?
The end of the coach is badly twisted from hitting the tunnel portal. I did notice that the roof looked bent in earlier pics.
Did you also notice that the crossing has been replaced by plain line?
Maybe to save it and until after the coaches have been dragged out then put it back so it doesn't get damaged?
AndyPJG
29 Jun 2012
Or with RAIB for evidence / analysis maybe?
Yes. the roof does look bent, IMHO that will probably mean it’s written off.
Regarding the crossing, I did notice but not sure why it was removed, perhaps it was already damaged?
