Grumpy Git
The block is only for the walkway. Why anyone would think it has anything to do with stopping the train can only be down to its actual location.
The footage from the CCTV camera mounted inside the arch should make for some interesting viewing.
No different to the many termini with the concourse immediately behind the stops.Although the block itself is the pedestrian walking route, so not sure putting that in the firing line is "for the best", other than what was a cheap and cheerful solution in the 1970s.
ITV Granada region pòsted the story at 11.46.
BBC North West haven't posted any news at all. Presumably they don't work Sunday mornings.
If it gets released by someone, which I kinda hope it does once the investigation concludes.The footage from the CCTV camera mounted on the underside of the overbridge arch should make for some interesting viewing.
Does anyone know if Kirkby and Ormskirk are the only locations where this split platform arrangement exists on the UK network?
Is it inherently dangerous given that this is the second time it has occurred at Kirkby?
Switching the clock back to the 1970s when the arrangement was implemented first at Ormskirk and then later at Kirkby might not a safer arrangement have been devised?
Perhaps with and island platform with one line on each side for cross platform interchange as it is more passenger friendly especially in bad weather(Yes I know at Kirkby the cutting would mean some serious earth works)?
If there was an island platform enough space could be left for accidental over-runs.
One wonders if outcome of the investigation might be a criticism of this split platform arrangement?
Modern standards would not simply permit such a design to be newly installed today.
Clearly not, because it is far, far safer than a conventional red signal with TPWS grids, which is what would otherwise have been there - compare it with, for example, platforms at Birmingham New St which have a mid-platform signal and two trains in each platform at once, or indeed with somewhere like Northampton which has permissive working (i.e. 2 trains in the same platform without a signal and overlap) for the purpose of joining portions.
Wouldn't it? It's hardly much different from just having a signal there, or indeed being an end-on station concourse with buffers as found all over the country. OK, that would have a longer overlap, but then the buffer stops and concrete block provided some mitigation.
I can't see any reason why you couldn't do it now, albeit with heftier buffers and a slightly bigger gap to provide an overlap.
It could be argued that (in the historic design) safety risk has not been lowered "as far as reasonably practicable" as would be required today.
That's what I suspect will be the case at Headbolt Lane - tracks still end on, but a greater separation between the buffers (and between the buffers and passenger circulation areas), standbank from the buffers, not having a road bridge directly over the top, and frangible platforms rather than a lump of concrete. That would apply modern standards and mitigate the consequences of a running into the buffers.
That's an interesting point given that it would be perfectly allowed for it just to be one platform with a mid-platform signal and an overlap, which would arguably pose a higher risk.
I believe Headbolt Lane is going to be two platforms for Merseyrail (eventually through platforms) plus a (sort-of) bay for the DMU. I wonder if they will be connected through like Ellesmere Port is?
An investigation is under way after a train derailed when it hit a buffer stop.
Twelve passengers and two crew members were on board when the incident happened at Kirkby station at about 18:35 GMT on Saturday.
They were checked by paramedics at the scene and no further medical treatment was required, Merseyrail said.
I wasn't necessarily thinking that - more sticking a few extra metres of platform at either end so that the buffers didn't have to be so close to the passenger walkway would strike me as the sort of "practicable" mitigation that would be applied today.
From the Headbolt Lane thread, yes - but one Merseyrail platform and the DMU platform will have their tracks "end on" as at Kirkby (except that the platform face won't be on the same side of the track as each other) - but I'd presume with a greater separation distance between them than is applied at Kirkby.
But I suspect this is still acceptable (thinking of Clapham Junction platform 2 where buffers were added mid length, and a 5 car electric train needs to draw up fairly close to buffers to fully fit in platform)
Kirkby has a slow approach speed, I think it's 10mph.The mitigation there is (IIRC) a 5mph crawl into the platform. Probably because there is no other "practicable" solution.
Initially perhaps.....but then you have to reduce to less than 5 mph to pass over the TPWS grid without causing an emergency brake application.Kirkby has a slow approach speed, I think it's 10mph.
It’s 15 into the platform. Down from 60 for passenger trains. 20 over 60 between Fazakerley and Kirkby.Kirkby has a slow approach speed, I think it's 10mph.
Odd situation to risk assess, could have overlap in front of buffers (so buffers only useful if ran through whole overlap), or no buffers (chance line beyond is empty).
I agree.That doesn't overly look like a 5mph collision!
It doesn't have to be less than 5mph at TPWS loops in bay platforms.Initially perhaps.....but then you have to reduce to less than 5 mph to pass over the TPWS grid without causing an emergency brake application.
I agree.bu
Google about the Sudbury buffer incident, a 156 hit the buffers (similar to the one at Kirkby) at I think about 7mph, causing minor damage to the unit and bent the buffers.
There it was 10mph for TPWS, let's say it's 15 at Kirkby (as just stated) I still think at lets say 13mph I don't think it would have caused so much damage and gone so far, I'm no expert, it's just how I see it.
Pendolinos IIRCWhich unit type was it that had an issue with transition between the dynamic brake and friction braking, thus causing a buffer stop collision or two in the past?
It’s 15mph in to the platform, it doesn’t mean it’s 15mph at the grids. I appreciate they can be set at differing trigger speeds but I’ve not seen them at more than 10mph. I always do 7 or 8 to be sure, but they’re generally set between 10 and 12mph as far as I’m aware.I agree.
Exactly...Of course of you had a case where the brakes had failed a TPWS application won't do anything apart from (I would guess) cut the traction power.
Indeed, if its sliding, with the brakes already in Emergency, TPWS will do nothing to slow the train down. The reports will show what happened, we could speculate for ages!Let’s just theoretically say that the train hit the TPWS ramps at about 25 with the brake in Emergency. It isn’t going to stop before the blocks, regardless of what TPWS does...
It was raining quite heavily here (Huyton, not that far away) at the time. Kirkby is known for being slippery.
