East-West Rail (EWR): Oxford-Bletchley construction progress
hwl
5 Feb 2012
It should be noted that this is not the 'Aylesbury Link' as in the spur from EWR to the existing (but currently lifted) line from Aylesbury to Claydon to enable trains to run from Aylesbury to Milton Keynes, but merely the reinstatement of the freight-only route to the household waste facility at Calvert.
Which would leave a conveniently small gap of ~1.75miles between the waste plant and EWR? Thus minimising the scope of work that EWR would have to do/fund?
BrianW
22 Mar 2017
IIUC (!) the (a?) local MP received 'undertakings' from HS2/the rail minister (Huw Merriman) that the construction of EWR over HS2 would be 'expedited'. I imagine that the early operation of EWR services between Bicester and Bletchley (before the General Election?) would be important?
There’s only a few hundred yards of plain track to lay and connect, there’s continuous track either side of the gap, ie to Bletchley and Bicester. They could do that gap in a week.
I think “expediting“ is just so much spin. They’re only a few weeks behind previously published schedules, and as we know from recent discussions they’ve got as far as the signalling in the vicinity being powered up.
On the other hand, I’d have thought opening before the election is all but impossible, and no one is expecting that.
hwl
5 Feb 2012
Hand over was meant to be June/July but plenty of slack in the programme from the planned Dec 2024 opening.
It's a manifesto commitment, if they move the election sooner than December 2024 then that is government's problem.
12LDA28C
14 Oct 2022
The back of beyond
Not even that far I would say. But of course the Aylesbury spur has not been confirmed yet despite widespread local support.
In the 4th picture, the tracks are quite wobbly, how do they fix that?
Following up your earlier question, the third picture in post #1378 helpfully shows the track construction machine (NTC) that I mentioned in my previous reply. As you can see it’s working away from the camera viewpoint, with the “wobbly” rails in the distance dropped some time ago, the blue and white machine is at the front of the consist, and the sleepers are waiting to be carried forward along the train.
Fazaar1889
5 Oct 2022
South East
Hs2 will run under the bridge in the first photo
Thanks guys.
Oh that's cool! Thanks!
On the latest satellite imagery on Google Earth Pro, there is a 2nd bridge (pic 1) just to the west of the HS2/EWR bridge, what is that for? When comparing it to the UK Rail Map, there isn't a railway there (pic 2). Google says there is something but not what is is (pic 2)
Snapper
28 May 2006
All over the place
For those interested in E-W rail and the work around Calvert. I had an official site visit a couple of weeks ago. You can find pictures of the E-W works here;
- and the HS2 works here:
AeM
8 Feb 2021
Berkshire
Great
Great pics, thanks Paul.
bnc2018
14 May 2021
Banbury, Oxfordshire
It's an underbridge for the road you can see in the centre. It used to run over the railway but as EWR has had to be lifted up to go over HS2, the road has been moved to underneath.
3973EXL
2 Feb 2017
What are the white plates on the sleepers between the rails leading under the 66 in the foreground?
They are the plates used to bolt together the concrete bearers of the Modular S&C delivered on the tilting wagons.
Photo show plates as delivered to site on S&C panel. Fixing position can be seen on the bearer end.
To add to the above explanation as well as being lowered the road has been diverted about 40m to the west, from a point just north of EWR it is still on a temporary alignment, it will eventually continue onto a big new bridge over HS2, but that’s not strictly an EWR matter. See image in post #1259 of what’s been done just north of the new road bridge.
I also annotated a picture back in early October, in post #1250, it’s a video capture looking to the east that shows the road still going over the original bridge a few weeks before demolition.
TiddlyPom
2 Feb 2021
South Cambridgeshire
Ah, I see, thanks.
chris2
25 Apr 2023
Southampton
A question about the Aylesbury chord from EWR…it appears from the photos of the area from Paul’s archive that the earthworks are there for the chord but no switches are being installed, so presumably there won’t be any track laid for it at this stage.
Presumably this is because the link isn’t confirmed, but then, the earthworks have been done and that would have cost money to do so I’m wondering why not put in the switches and enough track to remove the need to have to disrupt EWR in future when it comes time to building it? Presumably they’re doing it this way because it’s the cheaper option, but is there much in it? Any other reasons why you wouldn’t put the switches in now?
12LDA28C
14 Oct 2022
The back of beyond
I believe it was agreed that the earthworks would be done as a preparation in case the chord gets approved in the future which some commentators seem to think is more likely than not. However, laying switches and track at this stage would certainly be jumping the gun somewhat. Similarly, HS2 will be relaying the pre-existing but currently lifted line between Calvert and Quainton at 90mph capability in anticipation of the chord being agreed at some point.
Dr A.Johnston
6 May 2016
Tomorrow should reach the milestone of the East and West parts of EWR joined together, rails have been pulled and the track laying machine is in position. I wonder how much press coverage this will generate.
Some pictures from Jim Scott (one of the drivers on the scheme) - Reposted from Jim Scott @colasgrid from X
Thanks JIm - Great Pictures
Possibly a daft question, but if, (as I believe), the first photo in the previous post is the NTC arriving top and tailed from Bicester, how do they get the leading loco out of the way? I don’t think there are any intermediate crossovers?
Ah, I have the answer. There IS a temporary crossover just east of Bicester Road (Launton) at the Bicester end, [1] and the lead loco is taken off with the transit wagon from the front end of the NTC, and moves to the rear of the consist there. Then the NTC is propelled at a slow walking pace for the 5 or 6 miles to the worksite. So presumably the NTC is very limited in speed in the configuration in the second photo, where the front end is running using the single axle.
[1] The third photo in post #801 shows the temporary crossing.
Ballast seems in short supply look how low the track is compared to the standing water!!
I think that’s a temporary road/rail access point near Launton village, it’s probably not draining off the tarmac surface, but nothing to worry about.
rower40
1 Jan 2008
Is it just me, or does anyone else think that a track-laying train should have a "Gromit" cuddly-toy on the front?
fgwrich
15 Apr 2009
Hampshire
Sun Chariot
16 Mar 2009
I am so impressed at tbe transformation of the line.
In the 1980s and very early 1990s, I saw the ARC Whatley-Wolverton services on the route (mostly 56s, but I have a photo of one ARC mustard liveried 59/1 taking the service past Bicester Town).
And I travelled Aylesbury-Calvert-Bletchley-MK, on an NSE "Christmas Shopping Special" 108+115 trip back in 1992.
March 2020, Swanbourne was looking very sorry for itself; the station site was cleared totally, only a few months later. Visiting the site today, I am delighted to see the old line "re-born". Well done to all involved.
oversteer
26 Jan 2011
After many years of driving past the line, today was the first time I saw this signal lit up. I had to stop and take a photo to mark the occasion :)
Location same as previous post.
