Ex LNER (and Grand Central) Mark 4 sets for TfW
SuperLuke2334
23 Oct 2021
Hereford
Any ideas why Manchester to Swansea was cut down to just Cardiff on quite a few services today including what would've been HD05's diagram if it hadn't had an issue with the doors?
TfW showing ' issues with the radio between driver and signaller' on JourneyCheck.
BillStampy
6 Jan 2024
Llanharan
HD03 due to be on the early Cardiff start, if it can get back to Canton that is as it's joined the dogpile at Llanharan as 2L63 has something wrong as it's been there for 50+ minutes
Edit: it's out now heading back to Canton, how many diagrams do we expect tomorrow to run?
Lurcheroo
21 Sep 2021
Wales
HD02+67008- Will work 1W96 tonight then enter temporary storage at Holyhead, 67008 will come off the set to go light to Crewe tomorrow to go onto HD01.
Don’t suppose you happen to know when HD02 will find itself with a loco again do you ?
sd0733
7 Nov 2012
From what I've been told is/was the plan it should be heading to Crewe later this week or early next week once HD06 is finished.
4. HD01 and 05 off Crewe and HD03 off Canton plus HD04 should pick up the 4th diagram as the 10:52 off Cardiff as there's no set at Holyhead.
Those 4 sets aren't due exams so are planned out to cover all diagrams all week but requires 100% availability again
Lurcheroo
21 Sep 2021
Wales
Good stuff ! Any ideas on the next 5 car set ?
sd0733
7 Nov 2012
HD06 it's already formed up with 12461 added so just finishing its exam before it has a test run and heads back out.
All the TOs are now in the workshops, the line at Crewe is no more so its getting towards the end.
HD02 should then go straight to a 5 car with the addition of 12447 then HD04 (12434) and HD05 (12477) should be lengthened next time they're on a scheduled exam at Crewe.
Phil from Mon
28 Nov 2014
Beaumaris, Ynys Môn
Not totally sure what the plans are to be honest. The issue there now is on the Holyheads is that many of the catering staff now work 5 shorter days than 4 longer ones to take account of the reduced time A Manchester takes over a Holyhead so any return to those would need staffing changes. It's not insurmountable but a bit of a hurdle the Holyheads returning.
Thanks. I’ll keep my fingers crossed.
theblackwatch
15 Feb 2006
HD04 (with 67014) is actually on the 08.30 Manchester to Cardiff, so presumably came up on the early starter from Cardiff the morning.
sd0733
7 Nov 2012
Yes looks like they've swapped round with HD04 on the 04:35 and HD03 now going out on the 10:52.
Edit- Swapped again as HD05 now on 10:52 from Cardiff with HD03 now planned for the 12:49.
Lurcheroo
21 Sep 2021
Wales
Oh brilliant ! Great to see it all coming together. As always, thanks for the info.
87electric
27 Jan 2010
12447 was in set HDO2 (probably for a short while) in Nov 2022. All this swapping is hard to keep track of. Thanks for all the updates.
sd0733
7 Nov 2012
HD01-03 all ran as 4 car sets with a TO (124xx) rather than the TOD (123xx) vehicle from introduction until November/December 2022 when they had SDO fitted and the TOD vehicle added in lieu of the TO. These are now being added back in to make them upto 5 car.
craigybagel
25 Oct 2012
From April they will also be able to run at 90 between Shrewsbury and Crewe.
They need to get a move on with the signage then.
Is that after some track work was done, or is it just a reassessment of the speed limits?
I seem to remember that 175s, like 185s, originally didn't qualify for MU speeds, but that quickly changed when ATW took them on.
We were told it would be a blanket 90 for everything, with the MU speed removed.
I'd imagine just Swansea. Saves on clearance costs and also I don't know how many runs the 67s would be able to do without a refuel.
Allegedly that's why the original all day Swansea plan was cancelled. 67s don't have the fuel capacity to do two Swansea - Manchester round trips. Having seen how empty the tanks are when they get on depot with their existing diagrams,I can believe it.
TT-ONR-NRN
30 Dec 2016
Farnham
I guess having more would allow them to do Manchester Swansea by swapping sets halfway through the day, i.e. as the first round trip is completed and it arrives into Swansea, a second set pulls in from the depot to work the second one, but I guess it wouldn't be the most resourceful process.
Anonymous10
19 Dec 2019
wales
Or alternatively fuel them at Landore by detaching the loco. However that would leave the loco under the main shed an picadilly.
MP393
28 Jun 2021
North West
I think that idea is long out the window anyway, the sets reverse quite a bit and end up “wrong way” like when the booked empties via Warrington go mainline instead, engineering reversals at East Usk Jn early morning, or diversions via Chester. These days it’s just a lottery of which way round the set is rather than a planned orientation!
Caaardiff
9 Jun 2019
Swansea - Manchester is about 220 miles
Cardiff - Manchester is about 175 miles
Cardiff - Swansea is about 45 miles
Manchester - Crewe is about 35 miles
and the range of the 67s is about 800.
On that basis a diagram such as:
Cardiff - Manchester (175)
Manchester - Swansea - Manchester (440)
Manchester - Crewe (35)
Is 650 miles.
Switch the last to Manchester - Cardiff and that's 790 miles, just within the range of the 67.
The issue is that type of diagram doesn't give opportunities for maintenance swaps as it starts and ends at the same location, canton in this case, along with having the Holyheads in the mix.
Anonymous10
19 Dec 2019
wales
That is true bur surely you could change locos on the depot?
Is 650 miles.
Also doesn't allow for if there's an issue with only 10l of wiggle room. It'd be like permanently driving a car on fumes each evening.
craigybagel
25 Oct 2012
No issues with putting the engine under the shed at Piccadilly, in fact that's the officially preferred way around, it works better at Canton. In theory sets shouldn't turn, the Warrington ECS runs should use the same set each way overnight but there's still a big backlog of Crewe drivers who need to learn the route.
That said, there's not a hope for taking the engine on and off at Swansea, or anywhere else. It would require a shunter and quite a lot of time and hassle. More likely they'd just shunt the entire set up the depot and back.
Indeed - if there were lots of sets available it might be a good option but sadly that's not the case. More likely it'll change when we get a more fuel efficient loco, or at least one with a larger tank.
sd0733
7 Nov 2012
Presuming this is for HD07 tyre turning before re-entering service?
It's HD07 but it had a bit of a leak in roof of the TO so its gone to Canton to be repaired over the weekend. Its planned back out on 1W57 on Monday.
MCR247
7 Nov 2008
The 0435 Cardiff - Manchester is showing as running in an altered path on Monday 25th March with only standard class seating, is this expected to be a DMU?
sd0733
7 Nov 2012
That one should be a 67. One of a rather limited number for tomorrow though.
Diagrams tomorrow are only 2 and a bit, should be:
67008+HD01
06:27 Manchester-Cardiff
12:49 Cardiff-Manchester
16:30 Manchester-Swansea
67013+HD05
04:35 Cardiff-Manchester
08:30 Manchester-Cardiff
17:14 Cardiff-Holyhead
67029+HD07
16:49 Cardiff-Manchester
Tuesday should see 67014 on HD07 with those 3 sets working the Holyead, Cardiff and first Manchester diagram with the 4th, 04:54 Crewe-Cardiff etc subbed.
67029 is still awaiting its bogie overhaul Hence its very short diagram on Monday as its effectively being used as a super shunter/power sets on depot at the moment until it goes.
Anonymous10
19 Dec 2019
wales
67008+HD01
67013+HD05
67029+HD07
What's the likelihood of the 2042 arrival at Swansea on Wednesday being a mk4?
