TT-ONR-NRN
Currently delayed, and interestingly enough driven by the driver I recently wrote a furious complaint about, unless she’s got a twin.Great news.
Will go and film 010 for my YouTube channel.
Best if I don’t go off topic here, let’s just say she wasn’t very politeLol.
I wont ask what she did wrong!!
LolBest if I don’t go off topic here, let’s just say she wasn’t very polite
It’s currently sat at Cardiff Central awaiting a guard, now 17 minutes late.
EDIT: 1714 CDF - HHD now cancelled. Passengers will now be offloaded as guard has arrived and cannot work MK4 sets.
“Due to the inability of train crew to work this specific type of train.” is what the announcement says. Whoever made the announcement also confused matters more by mistakenly calling it the Manchester train, when of course it is the Holyhead train, so now Manchester passengers are asking if their train is also cancelled.RTT is reporting it as cancelled due to unknown cause.......
Now it has changed to an issue with the train crew!
Lol
Have you got to be a special guard to work MK4 sets then?
Cancelled between Cardiff and Shrewsbury according to RTT
You couldn't make it up!!“Due to the inability of train crew to work this specific type of train.” is what the announcement says. Whoever made the announcement also confused matters more by mistakenly calling it the Manchester train, when of course it is the Holyhead train, so now Manchester passengers are asking if their train is also cancelled.
So what has been allocated from Shrewsbury....?“Due to the inability of train crew to work this specific type of train.” is what the announcement says. Whoever made the announcement also confused matters more by mistakenly calling it the Manchester train, when of course it is the Holyhead train, so now Manchester passengers are asking if their train is also cancelled.
Can't see it on RTT.....It is going ECS to Shrewsbury. What an ongoing shambles
ThanksRealtime Trains | 5W96 1714 Cardiff Central to Shrewsbury | 21/07/2023
Real-time train running information for 5W96 1714 departure from Cardiff Central to Shrewsbury on 21/07/2023. From Realtime Trains, an independent source of train running info for Great Britain.www.realtimetrains.co.uk
And then the Portsmouth is out late too.Realtime Trains | 5W96 1714 Cardiff Central to Shrewsbury | 21/07/2023
No it couldn’t have as it was already sat in 1B at the appropriate time before the Holyhead was cancelled.And then the Portsmouth is out late too.
This is just standard Cardiff planning.
The Portsmouth could have used 2 given the Birmingham arrival was 1 minute after that and even allowing for time to clear the signals to allow the Birmingham to arrive the delay would not have been that large.
Of course it should not be the case that sending a unit to form a later train in behind a front train is problematic, but with TfW and the Mk4 (and presumably 197s given need for competence) it seems risky.
The point I am making is that planning should not put anything behind a TfW at the moment.No it couldn’t have as it was already sat in 1B at the appropriate time before the Holyhead was cancelled.
Total shambles. Wonder if the passengers were told that their train was going north but they could not use it because the guard had not been trained how to press the buttons to lock/unlock the doors on that type of train?It is going ECS to Shrewsbury. What an ongoing shambles
That's supposed to happen in Manchester, the 2030 is booked a unit anyway.67025 has been cancelled beyond Crewe on this evening’s 2030 Manchester Picc to Cardiff Ctrl. Passengers will need to transfer to a 2-carriage 175 for onward travel.
Yes, not great for customers needing to get off and get back on though, especially as some who were seated will doubtlessly rejoin to find they don’t have a seat anymore.That's supposed to happen in Manchester, the 2030 is booked a unit anyway.
Not great no, HD06 was supposed to stay at Canton with 1W23 to have been a unit until very late on so no unit was sent to Manchester an hour earlier to form the 20:30.Yes, not great for customers needing to get off and get back on though, especially as some who were seated will doubtlessly rejoin to find they don’t have a seat anymore.
I know I shouldn't bite but there's a lot more to it than just the doors (although even then the door controls are very different from and other rolling stock in the fleet). It's a 3 day course for guards and quite an intensive one at that.Total shambles. Wonder if the passengers were told that their train was going north but they could not use it because the guard had not been trained how to press the buttons to lock/unlock the doors on that type of train?
It's a course that after two years of having the trains in service you'd think the guard allocated to it would know.I know I shouldn't bite but there's a lot more to it than just the doors (although even then the door controls are very different from and other rolling stock in the fleet). It's a 3 day course for guards and quite an intensive one at that.
There's about a hundred guards at Cardiff Mainline depot (who work the train in question), at a time when the company has been struggling to cover services as it is. There's only so much that can be trained at a time without cancelling trains, and there's still a fair few at Cardiff that need doing. Obviously the conductor shouldn't have been rostered to the job in the first place, so someone has made a mistake, but it is what it is.It's a course that after two years of having the trains in service you'd think the guard allocated to it would know.
I seem to recall that when Chiltern and ATW (for 'Gerald') started using 67s with mark 3 DVTs there were reports that the locos also needed to have remote fire-suppresion system fitted (in addition to the mods needed for the loco and DVT to 'talk' to each other) before the loco could be used to push from the rear with no member of staff on the loco. Presumably that fire-suppresion system is still required for the mark 4s.There's an extra socket fitted to the front of the loco, to enable the '42 way' cable to be plugged into the loco. This allows the loco and DVT to talk to each otherForgive me for asking, but what exactly needs modifying with the 67s?
They worked perfectly well when the Mk IVs were on East Coast on the Newcastle - Carlisle drags.
AFAIK on the East Coast they were used to drag the entire set, any 67 can do that, as can pretty much any loco but they were never used to be driven from the DVT with the 67 on the rear
The people from KeolisAmey who were responsible for the vast majority of TfW's original fleet plan certainly were thinkinkg about a more-homogenous fleet since they insisted on replacing the 158s and 175s with new stock - not just the 150s and Pacers. Don't forget that at originaly (when it was run by KeolisAmey) TfW Rail Services were only planning to have three mark 4 sets, replacing the three ATW mark 3 sets (although it was always the intention for the mark 4s to be deployed slightly differently to the ATW mark 3s).The MK4 are much better than anything else, but feel like TfW felt they should have an "Intercity" train without actually thinking about the benefits of a more homogenous fleet.
There was of course a period when the whole industry was unable to conduct driver training due to COVID distancing rules - presumably this also applied to guards to some extent so the delay to getting all crews fully competent is understandable.Total shambles. Wonder if the passengers were told that their train was going north but they could not use it because the guard had not been trained how to press the buttons to lock/unlock the doors on that type of train?
So much for having the trains back under state control and not a private company!
That's HD07, when the Guard keys in at the DVT door panel the lights go off. It's just one panel so obviously an electrical gremlin there as it doesn't happen when key on at any of the coaches.I made a short journey on 1V18 yesterday evening. It was one of the ex-Grand Central sets, although I don’t know which one exactly. The interior carriage lights were switching off at every stop, and the emergency lights at either end were illuminating. Does anyone know what might have been causing that? The loco not providing enough power when at a standstill, or otherwise?
