First Group Sheffield - London via Retford open access proposal
duffield
31 Jul 2013
East Midlands
Hull trains has announced provisional timetable from Sheffield to London
The final service from London to Sheffield actually appears to be timed slightly faster end to end than the fastest EMR services. Southbound services are not so good timewise, presumably because they sit at Retford for a while.
GardenRail
26 Mar 2023
Another pointless service. Just leave the job to EMR. Sheffield doesn't have enough capacity for such North end departures. And it's going to generally take longer than EMR. It will never leave on time because of the traffic before it.
simonsays
27 Jan 2024
Uk
Bit like your post, if the company has decided it can make it work that's up to them to try. If it doesn't they will soon stop.
Sheffield station is well overdue a revised layout some bidirectional signalling would improve the flow. Ideally the north end will be looked at as the wires get nearer !
Bristol
The problem is if they can't make it work they stuff everybody else up in the process.
There's only so much you can do at the North End however, and to do anything big takes money nobody currently has, or is likely to have in the timescales required. There's certainly room for improvement (see the speculative thread) but big-buck items like 4-tracking or Grade separating the North end are unlikely.
GardenRail
26 Mar 2023
What do I know..... I just signal the things 12 hours a day at Sheffield. Passengers can easily travel to Retford or Sheffield and change.
Killingworth
30 May 2018
Sheffield
Given the number of times TPE westbound South Pennine services thay come into Sheffield late adding more services through that bottleneck won't improve matters.
There are other aspirations for extra services through that corridor, all desirable for a few users but all likely to add more delays for many more.
AlastairFraser
12 Aug 2018
Surely they could rebuild Victoria station, IF they put down the cash for a basic island platform station?
Harpers Tate
10 May 2013
There clearly are capacity issues around Nunnery, but somehow, "they" managed to squeeze in an extra arrival and departure every hour when the Gainsborough Central shorts were running. Which tends to suggest that there is capacity for (at least) 2x more movements via Darnall per hour.
Killingworth
30 May 2018
Sheffield
They could. Suggestions to build a new station at Victoria tend to overlook why it closed in the first place and several reasons why it's not realistic to reopen now.
1. It's in the wrong part of Sheffield for most users.
2. It would offer no connections to other rail services.
3. A basic station would certainly not attract new users.
4. Building a new, even basic, station to modern accessibility standards would still cost many millions.
5. You'd still have congestion issues in the Nunnery area.
But all that has been discussed before and belongs in another thread.
Bristol
The only way I could see Victoria being reopened is if the Stocksbridge branch got made into part of a Sheffield Overground/S-Bahn/Metro idea. But that's a different thread completely. The new London service will want to be at Midland to connect into local traffic and the tram, for feeder traffic into the OAO business.
GardenRail
26 Mar 2023
And the timetable fell to pieces....
AlastairFraser
12 Aug 2018
Not much good for connecting with the rest of the network.
But if you imagine this open access service as a kind of a low cost express route into London, a less convenient station fits into your typical low cost operator profile.
It does have those advantages, but it all depends how much Hull Trains wants to expand this business and compete with EMR in the future. It looks like a profitable market to tap (especially if you can abstract from coaches).
Want and able to get seem to be very different words in this scenario.....
eastwestdivide
17 Aug 2009
S Yorks, usually
And prior to that, there were two stoppers an hour on the line to Doncaster (never came back after the pandemic). Plus regularly two XC per hour instead of the one-and-a-bit average now.
Killingworth
30 May 2018
Sheffield
So capacity needs to be preserved for their return. Plus an extra hourly fast to Leeds service and an extra to Hull.
YorksLad12
5 Feb 2020
The second fast service requires the rewrite of the East Coast timetable, I seem to recall from threads passim.
Killingworth
30 May 2018
Sheffield
TfN are seeking input into a consultation on TPE and Northern services from 2027. Nothing happens quickly with the railway. The knitting is formidable.
No open access operator is boing to commit to buildign a new station for a handful of trains a day.
357
12 Nov 2018
Unless there is sufficient demand for other trains to stop there and they make money from charging TOCs station access fees :lol:
And who is paying for the other trains? ;)
fishwomp
5 Jan 2020
milton keynes
The one that reopens the W******d line (using strategic reserve of steam locos from the tunnel).
I'd wonder whether Meadowhall would be a better target these days - ample parking, better road connections to the region. Needs the Woodburn Jct east curve restored - 500 yards. Why ever was that lifted..
357
12 Nov 2018
And who is oaying for the other trains? ;)
I've got no idea of the geography or detail of the situation - I'm just thinking about a Southend Airport type situation where the station is/was owned and operated by Stobart.
mike57
13 Mar 2015
East coast of Yorkshire
Capacity at Sheffield has been discussed here before, and any improvements to the north are going to be very costly. (likely in the 'never going to happen' category)
So a possible (simpler?) solution, London - Sheffield services and Nottingham - Liverpool services both enter and depart to/from the south. Could elevated bay platforms be constructed at walkway level at the London side. Its a falling gradient into the stations, so would actually be less gradient. There is the issue of a couple of overbridges close to the station throat, but if that could be addressed would it help? Advantage is you wouldn't be removing large amounts of bedrock.
This would free some platforms off, but I agree does nothing to increase capaity going north, but getting the two EMR routes separate from Northern, XC and maybe Hull Trains might help
