At one time they had a fleet of bendy buses for the Park & Ride and the bendy “ftr” buses which will have taken up a lot of roomSurprised there is enough room at York for all these extra buses
I suspect the Team Pennine service has a faster average speed than the First one though!Wondering why they've picked X1 as the route number, rather than resurrecting the X36 number that was previously used for a fast Huddersfield to Halifax service. X1 is also used by Team Pennine's Wakefield to Holmfirth service, which whilst it doesn't overlap with Huddersfield to Halifax, will be a pain for anyone looking up the timetables on the Metro website.
Though of course it is Team Pennine's service which breaks convention rather than First's.
While those improvements are very welcome, I'm less impressed with some of the reductions on the 590-2 group, which will see only an hourly service on some evenings between Todmorden and Halifax, the worst it has been in the 40 years I've lived here. The reduction from a fifteen to twenty minute headway off-peak is manageable I suppose, assuming all journeys run (ha!). I look forward to seeing the actual timetables when released.
Wonder what the thinking behind withdrawing the 200 is? I know it's a staff bus that they run in service rather than being dead mileage. Maybe the operational flexibility of not having to run it to a timetable is worth more than the tiny bit of revenue it must make?
I don’t think the frequency of each was ever known at that pointSome bits are welcome, but it's a reduction from the original idea which would have seen 501s, 503s and X1s co-existing.
My understanding is that Burnley will have two through buses to Halifax an hour at 20/40 whilst Rochdale will have one through bus and one short to Todmorden to give an even half-hourly service.Regarding the situation with 590-592 group I wonder whether with the changes they will be going back to the timetable where technically every hour you'll be able to get a bus from Rochdale-Burnley? In other words you'll get a 590 from Rochdale-Todmorden which will then change at Todmorden to do either a 591 or 592 from there to Burnley.
I seriously doubt there would have been more than the 8 buses per hour they have gone with
It’s typical that when they are increasing the service from 4 to 8 buses per hour, negatives are still attempting to be found
The X1 apparently is not an express; it's stopping at all stops on the route.I wasn't attempting to find negatives. I was finding a negative which will affect people I know - their evening service from Huddersfield to West Vale being halved will come as a bit of a surprise to them given they're expecting more buses.
I was surprised that the X1 is to be every 15 minutes through the day. When there's previously been an express between Halifax and Huddersfield, they've only managed that frequency at the peak. It's also odd to have half of a low frequency evening service being an express.
Another two Kites, which have been recorded on buslistsontheweb.co.uk to be the following:Two more to add to the list, taken from buslistsontheweb.co.uk:
63583 - ML73EAK
63584 - ML73EAM
I'm still expecting to remain as two buses an hour, basically a similar format to that of the 39 and X39 between Bath and Bristol where the 39 running the evening journey's.Some bits are welcome, but it's a reduction from the original idea which would have seen 501s, 503s and X1s co-existing. Anyone who travels between West Vale and Huddersfield is going to find each journey 5-10 minutes slower with a halving of the late evening service.
I'm hoping a decent frequency will continue into the early evening before it drops to the current combined 2bph.
Anyone know if the 501/X1 is likely to go back to having a reasonable time for its last bus? Leaving Huddersfield used to be possible after 2300 - currently it's 2218!
I'm putting it down to increased flexibility and to free up a spare bus or two that can be pressed into service.Wonder what the thinking behind withdrawing the 200 is? I know it's a staff bus that they run in service rather than being dead mileage. Maybe the operational flexibility of not having to run it to a timetable is worth more than the tiny bit of revenue it must make?
I still think that First are missing a trick by not inserting a 593 into 590/591/592 Halifax - Todmorden Rochdale/Burnley block which could run as far as Hebden Bridge (terminating on New Road after running via Commercial Street and Crown Street), thus giving the Upper Calder Valley four buses an hour.One thing I am curious to see is at the times of the week when it will be an hourly service between Halifax and Todmorden. Incidentally, whilst the previous daytime six buses per hour might have seemed excessive from Todmorden to Halifax, it probably wasn't that excessive from Hebden Bridge eastward. Even when the 590/2 offered only two buses per hour from Todmorden, they were joined at Hebden Bridge by the 591 from Heptonstall and 593 from Old Town, although it was a 10/20/10/20 split unfortunately. Eventually the 20 minute gaps were filled by Halifax - Hebden Bridge short workings numbered 595, largely to deter competitors from slotting into those gaps.
EDIT - I've just noticed that the Metro website actually says the reduction to hourly on late Mon-Thu evenings is Halifax to Hebden Bridge, not Todmorden.
I think it would be extremely tight to get a full size single or double decker round the narrow double dogleg from Commercial Street into Crown Street via Albert Street in Hebden Bridge. Probably better to run through the town to the turning circle for Heptonstall and take in a few more stops.still think that First are missing a trick by not inserting a 593 into 590/591/592 Halifax - Todmorden Rochdale/Burnley block which could run as far as Hebden Bridge (terminating on New Road after running via Commercial Street and Crown Street), thus giving the Upper Calder Valley four buses an hour.
I recall the old M62 service which was scrapped and eventually returned as an X80.Wondering why they've picked X1 as the route number, rather than resurrecting the X36 number that was previously used for a fast Huddersfield to Halifax service. X1 is also used by Team Pennine's Wakefield to Holmfirth service, which whilst it doesn't overlap with Huddersfield to Halifax, will be a pain for anyone looking up the timetables on the Metro website.
Are they going today?Any news on the York side given that the bendys are meant to be going today and the 59 and 2 are having some route changes to allow for larger buses to operate?
On 501/X1 last bus is 2310 501 from Halifax and 2358 X1 from Huddersfield. Mon-Sat. There’s a 0410 bus from Halifax Bus Station too. Hopefully First have checked it’s open this time unlike the 72 debacle!I'm still expecting to remain as two buses an hour, basically a similar format to that of the 39 and X39 between Bath and Bristol where the 39 running the evening journey's.
As for the last 501 to Halifax (or Huddersfield for that matter) I'm not expecting to see anything run after 2300 even though I'd prefer to see at least a 2320, 0020 and an 0120 from Huddersfield with a 0001, 0100 and 0200 from Halifax as at least I know I'd be able to walk it home from Ainley Top or Elland if there were some latish journey's.
Given it was only announced on Friday it’s unlikely to be anything other than business as usual for now.As an outsider, what will be the effect of the takeover by First of York Pullman?
First will probably take on the extra services eventually, make a song and dance about how they've expanded the York network, then a year down the line hand back the contracts for the marginal services. I wonder if First tickets will be able to be used ie First Day, before long?As an outsider, what will be the effect of the takeover by First?
Very little immediately. It’s being run as a separate business, like the Ensign purchase, for the first 2 yearsAs an outsider, what will be the effect of the takeover by First of York Pullman?
Given a FirstDay is the same price as an AllYork Day, there’s no reason for this to change for nowFirst will probably take on the extra services eventually, make a song and dance about how they've expanded the York network, then a year down the line hand back the contracts for the marginal services. I wonder if First tickets will be able to be used ie First Day, before long?
just 36528 outstanding from the deliveries of new electric vehicles to this fleet
Bendys used today in case anyone forgot about the change, rather than lose the roof on a decker lolI was in York centre today and saw lots of bendys on route 2, operating on the altered route returning to the centre via Bootham and not via Leeman Road.
So they're going tomorrow?Bendys used today in case anyone forgot about the change, rather than lose the roof on a decker lol
