GWR Class 800
The Ham
6 Jul 2012
It would be a pretty major issue if the trains couldn't fit in the platforms at the one station on each route that almost every service uses.
It depends on the impact of it not fitting to platforms, SWT have a number of stations which see daily services which do not fit the platforms. However there'll be stations where by bit fitting it blocks a junction which then messes up the network.
23 Nov 2015
I believe ETCS / ERTMS is planned as far as Doncaster for now, at which point 140 mph will be possible where the infrastructure permits.
Given the frequency with which the knitting comes down, I would say the infrastructure doesn't permit it anywhere.
sprinterguy
4 Mar 2010
Macclesfield
Where would an 11-car set not be able to fit? Surely only Kings Cross and Paddington.
An 11-car IEP set, at 286 metres long, would fit in platforms 0-4 and 6/7 at Kings Cross (but would be a few metres overlength for platforms 5 and 8).
It'd be overlength by almost a full carriage length for platform 4 at Newcastle (causing potential conflicts with adjacent platforms) and platforms 3, 4 and 5 at Peterborough, just over a carriage length at Retford and by two carriage lengths in the Up platform at Durham (which due to the positioning of the platform end signal is currently a tight squeeze when a mark 4 set has a loco leading the DVT) and both platforms at Berwick-upon-Tweed. A 9-car set is the very maximum that the latter two stations can accommodate at present with all vehicles platformed.
Some of these limitations could be overcome through platform extensions or the use of SDO as per the programme of East Coast Capability works currently being undertaken for the IEP to allow 10-car formations to operate, though not necessarily all.
In the current Rail, the ECML boss Rob McIntosh says that renewing the basic infrastructure is his main priority (OHLE, power supplies etc), as it is coming up to life expiry.
South of Hitchin the overhead is nearly 40 years old.
Plus such things as eliminating level crossings.
He mentions major capacity improvements in CP6, but higher speeds are not mentioned anywhere.
If you factor in HS2 reaching York, and the problems getting a 140mph GW route, I'd say 140mph on the ECML is not going to happen, at least south of York.
Maybe York-Darlington will be upgraded to link into HS2 when it arrives.
hulabaloo
5 Apr 2015
It's probably not in their best interest to improve line speeds when they have expensive HS2 tickets to sell anyway.
D365
29 Jun 2012
There's still going to be semi-fast trains that can take advantage of enhanced line speeds.
Why are HS2 tickets necessarily going to be expensive?
jopsuk
13 May 2008
Not fitting into Paddington ot Kings Cross would be ptetty "terminal".
Ahem
Terminal platforms are hard to lengthen due to busy concourses at one end and station throat pointwork at the other end. Overhanging the platform can block part of that throat, blocking one or more other platforms. IC trains typically have long layovers to allow for cleaning and for stocking of catering (and for paper reservations to be set out, if used). Over hanging points for two minutes is a bit of a problem. For 20-30 minutes is a big issue.
It's not as if GWR and VTEC are not used to short platforms- both run HSTs to short platforms without a major issue. But really cannot do that at a terminus, especially a busy London one.
I have once got a train that terminated, end of the line, at a short station. But Westport, in rural Ireland, is a different proposition. And the loop was still long enough for the loco to run around.
The Ham
6 Jul 2012
I would guess (from the profile picture) that they are basing their assumption on what happened on HS1.
However, unlike HS1, there will be need for semi fast services which run "parallel" to HS2 and so for those with the time but not the money there would be an alternative route.
However we digress...
There's something like 130 miles of route south of York where speeds of 140mph of higher will be possible after OHLE upgrades and with in-cab signalling.
Edit: It's 135 miles or so to Darlington, only 100 miles give or take south of York.
The Ham
6 Jul 2012
Ahem
It still depens on the impact of not fitting, overhanging so as to block points is a problem, however overhanging so the end of the cab isn't alongside a level but of platform (but the driver's door was and it didn't block access to other platforms) wouldn't. Neither train "fits" but only one would be an operational problem.
D1009
22 Feb 2012
Stoke Gifford
Class 170101
1 Mar 2014
Durham is currently being extended according to
Rail Technology Magazine Durham Extension
jopsuk
13 May 2008
as the routes are being prepped for 2x5 car formations, are there allowances in the design and contracts for the 9 car sets for potential extension to 10 car? 11 car would seem to be (as discussed ) a step too far but 10 is clearly feasible.
Colind
29 Jul 2015
Michael Portillo is shown round the IEP factory on the 5th January edition of Great British Railway Journeys, available on Iplayer.
The design supports up to 12 carriages per train.
800001
24 Oct 2015
Ooh, that's interesting: I wondered whether it would be possible to extend the Up platform over the A691 bridge - apparently it is.
Next 4 weekends, East Coast is closed Darlington - Newcastle, for platform extension at Durham, and overhead and track work at Croxdale.
glbotu
8 Apr 2012
Oxford
Was at Durham station this morning, there's a big platform-shaped thing on the A691 bridge. It looks like it's partly cantilevered over the A691, it's not surfaced or connected to the existing platform though.
tomoufc
12 Dec 2014
Apologies if this has been asked before, but I have searched the thread and cannot find the answer.
Does anyone know how much more the government is having to pay to convert the GWR class 801s into bi mode, or where I may be able to find out.
Thanks
WatcherZero
25 Feb 2010
Depends how you view it. The government isn't buying trains its renting them on a per operated diagram basis so it will be paying the higher rental fee of bi-mode rather than pure electric. Its not costing them any money up front.
Last thing I saw, the DfT had not decided whether to pay up front or spread the cost.
tomoufc
12 Dec 2014
Thanks. In that case, do we know how much extra the government is paying in rental costs?
It hasn't been determined. As said up thread, the decision as to paying up front or sticking it on the rental hasn't been made yet.
And I can't see why the rental would be significantly higher than for the 800s already on order before the switch. If anything, by pure economics theory, it should lower the cost due to the increase in number of engine modules (lower cost per-unit).
