Well I've noticed that you pounce on anyone who has anything to say about IEP that isn't brilliant.
So people posting what is often nonsense, with zero supporting evidence, should just be allowed to get on with doing so, should they? There is a difference between picking people up over that sort of thing and being a cheerleader for the IEP, which you have accused me of on a number of occasions.
If the aim of this thread is, ultimately, to aid people's understanding, with points debated along the way, then letting wrong information or wibble about things like the slope in the floor go unchallenged is not going to help that process, is it?
For what it's worth I've been told in electric mode they are very good trains. But they just haven't got the power in diesel mode at higher speeds. And I seem to remember I was lambasted for pointing out RF's comments to that effect a while ago with the IEP supporters claiming the RF was just biased against the whole thing.
I'm sure they are fine and dandy running running fast on 25kv power - that was what they were designed to do, wasn't it?
But by higher speeds on diesel, could you expand a little on what you mean?
Are we talking speeds in the 100mph-125mph range or speeds below 100mph?
Given that the trains were never expected to be required to run day in, day out at 125mph on diesel, it's hardly surprising that they can't match a purpose-built 125mph diesel train. That the GW electrification is running late is not Hitachi's fault.
If it's a problem at 100mph or below, then that would be cause for concern, given that is the speed range of most of the routes where diesel running will be the regular mode of operation.
An IEP has yet to turn a wheel on any bit of the GWR network (or the ECML offshoots either) where this will be the case, so maybe let's wait and see how they actually get on with the likes of the Cotswold Line, with bursts of 90-100mph running interspersed with station stops at short intervals.
Also, what engine ratings are we talking about? The normal mode for Class 800, where the engine management system does not call for the full power rating as a matter of course, or the full-bore version, as per the AT300? Details of the testing programme seem scarce, so I've no idea. Does anyone else know?
Ow and by the way the reason I chose to post the point in the end is because why should I be put off posting something factual just because it doesn't sit well with others views of the project.
Well you could have posted both the 'bad' and 'good' points at the same time last night then, couldn't you? Instead of which we have to wait today for you to tell us what was said about performance in electric mode.
