Hope Valley Capacity Scheme updates
GardenRail
26 Mar 2023
It seems the useful Earles loop is very carefully guarded even against other freights.
Would said freight have fit in Earles Loop? It's not particularly long. If we send a freight early from Sheffield, we have to take into account whether it will fit in Earles Loop, otherwise, once we've committed, it's got to get as far as the Chinley Triangle.....
Bristol
Indeed. Earles Loop is listed as 358m in the Sectional Appendix, compared to 548m for the Up Heeley Loop. Bamford Loop is 640m. Standage on the Dore Curve isn't given, but the distance between the junctions is 41 chains, (0.5mile, 825m although standage will be less for overlaps/clearance points/signal sighting).
The normal working assumption for aggregates is 450m at max length, but Hope Valley trains may well be longer than that.
Killingworth
30 May 2018
Sheffield
However looping a stopper at Earles rather than at Heeley might allow both it to make better time when a TPE is delayed by 10 minutes or more through Sheffield - and reduce the chances of the TPE catching up if the stopper isn't looped at Heeley.
Curious to hear platform announcements today warning of short platforms at Hope Valley stations and to travel in front three carriages if alighting there. Fair enough for a 6 car train but surely not for 15x and 195 4 car trains?. All the platforms were extended to 4 car length only 3 or 4 years ago.
Bristol
Earles is only a goods loop, passenger traffic can't be looped there.
Killingworth
30 May 2018
Sheffield
At present, but that's been for scheduled services. An occasional special train has sheltered there in service. Can't immediately recall if the last was West Coast or LSL. Some time ago due to the ongoing work.
No reports from local residents of any significant work at the West View Lane site last night despite them receiving warning letters about noise - but too wet to go and check!
GardenRail
26 Mar 2023
To use a goods loop/line with a passenger train requires written permission from higher up for the Signaller, to be able to do it, if it's planned.
In emergency circumstances Control can authorise.
It won't be getting used for regular use of passenger trains because it would need resignalling and bringing up to passenger standards. Maybe when Earles shuts in many, many years.
Killingworth
30 May 2018
Sheffield
2042 or thereabouts! Although alignment of business cases, comonsense and funding have sometimes made the unthinkable happen sooner. I doubt it will here.
Bristol
as @GardenRail says, you need an Ops Manager's authority to loop a train. Specials request permission up to 16 weeks in advance to allow for the necessary checks and reviews to take place, including any work. Often specials using goods loops will require points clipped and scotched or trains held back at signals behind until the train is confirmed at a stand by the driver. Unless all hell had broken loose, getting permission on the day to bring the sidings to a stand while the loop was clipped up by the MOM, then to loop the local and let it back out to unclip the points before letting any shunting resume, would cause more delay than letting it go through ahead of the TPE.
59CosG95
18 Aug 2013
Between Beeston (Notts) & Bedlington
This has snuck in under everyone's radar - headspan to portal conversions between Stockport & Hazel Grove!
This one here's at Davenport.
(To update, both the headspans done that weekend (28/29 September 2024) were at Davenport; Woodsmoor & Hazel Grove remain untouched at present.)
Bristol
Has anybody got/done a map of where Headspans still exist in UK electrification and which sections are undergoing conversion to portals (full or partial)?
Nicholas Lewis
9 Aug 2019
Pretty well anywhere electrified in the 1970's onwards that has multi track lines generally 3 or more. They will remain in most places unless they have proven to be vulnerable to weather or are on sections of track where they are upgrading line speed and even then its only limited replacement.
Bristol
Well, I'm not not volunteering myself...
:D
Thanks
Only up until the end of BR electrifications in the early 90s. By the time of the post-2009 schemes the policy had been set of no headspans (with limited exceptions such as heritage station buildings) and indeed had probably swung too far the other way with the over-engineered structures on GWML. I don't know if there were any headspans in the few bits and pieces of electrification done between those dates.
Nicholas Lewis
9 Aug 2019
Thanks for providing that clarity
td97
26 Jul 2017
The Hope Valley project did an assessment which detailed the non compliances and general poor condition of the Hazel Grove area OLE , but this was deemed beyond the scope of the project and not remedied. So now it seems the maintenance team have actually acted on this in a reasonable timescale. All for 3 electric trains per day!
InOban
12 Mar 2017
The scaffolding/sheeting were no longer there today when I passed by on the train. All nicely painted dark green. Couldn’t see if it was open or not
I assume that the footpath did in fact open? With due celebration after 2 years?
Killingworth
30 May 2018
Sheffield
Curious that the headspan work is headlined Hope Valley. Davenport is in Stockport, Greater Manchester on the Buxton line. Perhaps someone wants to highlight it as the start of full electrification of the route to Sheffield.
The Hathersage West footbridge was finally opened at the end of August, one month before the footpath closure authorisation expired. I must go and walk across.
59CosG95
18 Aug 2013
I suspect the "Hope Valley" part is an anachronism brought about purely by the fact that the TPE & EMR services that use the Hope Valley Line run through Davenport, Woodsmoor & Hazel Grove.
Even though they use diesel units, of course!
plugwash
29 May 2015
and it's extremely rare for an electric unit to go to hazel grove anyway!
Service patterns seem to vary.
Not so long ago, pairs of 331s were regularly running hazel grove to blackpool. Right now though the hazel grove terminators are only running as far as picadilly and they seem to be using 15x for some reason.
jfollows
26 Feb 2011
Wilmslow
Because they interwork with the Buxton services currently, I think (and one of the evening Stockport-Chester services).
Otherwise 2H07 17:58 Piccadilly-Hazel Grove & return ECS gets used to scrape the wires.
Jamesrob637
12 Aug 2016
08:10 Hazel Grove to Manchester Piccadilly is a booked 323 also
Just a gentle reminder this is a railway infrastructure thread to discuss updates regarding the Hope Valley upgrade. Timetabling updates would belong in the timetabling section, while any posts of a speculative nature (such as those concerning rolling stock in the future on the line) belong exclusively in Speculative Discussion please. Many thanks.
GardenRail
26 Mar 2023
Everything with regards Railway Operation has been completed. Just a lot of railway junk needs tidying, but nothing needs doing that will improve the running of trains.
