House Of Lords Debate - End 'disgusting' train toilet sewage
Marvin
7 Jul 2011
Maybe so, but in the case of a train passing at speed the material in question is atomised and spread around, possibly reaching a range of people nearby who wouldn't even know it had happened.
If that happens, it's been happening ever since trains with toilets were created. Is there any evidence that public health suffered from the amount of atomised sewage being flung around, or indeed that public health improved when retention tanks were introduced?
And if it's not actually doing us any harm, is it really so vital that it gets fixed (at massive cost)?
Quite so, but in our health-conscious and litigious society I don't think the fact it's been going on for 100+ years is necessarily a reason for it to continue.
ryan125hst
2 Jun 2011
Retford
Ahm, First don't operate 185's. The one's Dan is talking about are operated by Arriva. (I'd write to Branson if I was you!)
First Transpennine Express operate Class 185's on most services. You've lost me on that last sentence?
Surreyman
29 Jan 2012
For DMUs: 142s, 143s, 144s, 150s, 153s, 155s, 156s and some? 158s.
So basically the majority of the Northern Rail fleet do it!
And for EMUs; - 317 (The 317/1s may have been fitted with retention tanks, not sure if that is still the case?), 321, 322.
All other AC and all DC have either retention tanks or no toilets at all.
I am guessing that as and when 317s/321s/322 are refurbished and fitted with Disability compliant Loos, that retention tanks will be fitted.
Hauled stock/HST, all Mk3 stock except Sleepers and refurbished Chiltern.
The tracks at Liverpool St, Paddington and Manchester Piccadilly aren't the 'sweetest'.
Lockwood
4 Apr 2013
I'd guess an extension of logical fallacy.:
You blame A.
A is believed to not be responsible, B is to be blamed.
Therefore, since you think that A is responsible for B's problem, you should contact C who is unrelated to either A or B.
wbbminerals
16 Dec 2010
some? 158s.
Does this explain why they often (maybe about 30% of the time) smell like a voyager? I didn't think any Northern trains had septic tanks. Personally I would rather it went on the track than have the occurance of carriages stinking out because the toilet is full of 'waste' that won't flush away!
5 Aug 2011
Given the majority of those classes should be withdrawn by 2020 under DDA legislation then I agree with most people on here that the cost of doing so is not worthwhile for the few years benefit. As for the 156's and rest of the 158's would it be worthwhile during their next overhaul as they have a few years service left correct.
Domh245
6 Apr 2013
nowhere
Perhaps, as mentioned earlier, because when P-Way staff are walking the track, finding any "leavings" that aren't "atomised" such as sanitary towels or nappies, or even someone's waste having flushed when the train is at a standstill, is a bit on the nasty side, especially if you step onto it when walking about.
ryan125hst
2 Jun 2011
Retford
Surely sanitary towels and nappies shouldn't be flushed down the toilet anyway! If passengers are doing this, is there any wonder that the vacuum toilets on modern, retention tank fitted, trains are becoming blocked and then being locked OOU! :roll:
If you think that any significant number of those trains will be withdrawn by 2020 I think you are naive.
Passenger growth and perrenial claims about overcrowding and short formation makes withdrawing any unit political suicide at the present time.
GatwickDepress
14 Jan 2013
Aye, there's a lot of crap on the lines up north. Then there's all the sewage they dump onto the tracks.
sprinterguy
4 Mar 2010
Macclesfield
According to this recent report from CIRAS, this is indeed the case, as the Northern 158s have been fitted with retention tanks:
http://www.ciras.org.uk/report-libr...rom-septic-tanks-on-class-158-units/?tid=1418
I wonder if there are any 158s that haven't been retro-fitted with CET tanks at this stage, then? Certainly, the evidence suggests that Scotrail, Northern and SWT units have all been fitted, and all the remaining ATW and EMT operated units have also undergone a high quality refurbishment in recent years that could have included such an alteration.
northwichcat
23 Jan 2009
Northwich
The 159s were fitted with retention toilets and apparently the 3 car 158s that went from TPE and got converted to 159s got them at the time of conversion, so I imagine the SWT 158s were done as well.
Northern have a mix of 158s: ex-FNW, ex-CT, MetroTrain, ex-Wessex and ex-TPE and they haven't done a full refurbishment at any time so they may well have a combination of ones with and without retention toilets.
sprinterguy
4 Mar 2010
Macclesfield
The CIRAS report that I linked suggests that they are all fitted with CET tanks, but with different toilet designs:
Northern are aware of the issue the reporter highlights. The fitment of Control Emission Tanks (CETs) to 158 units was conducted in partnership with Network Rail several years ago as part of a national program.
Northern are, however, impacted further by the fact that its 158 allocation has been in a majority of cases cascaded fleets from other operators. This has resulted in many different toilet pan arrangements.
NLC1072
17 May 2010
Ireland/London
So effectively does this mean a portaloo will have to follow each permanent way gang/member of staff? As a lot of their "waste" goes on the ballast...
6 Sep 2011
Blackpool south Shore
Certain people seem to use the WC as a dustbin. Sewage works have a rotary sieve to remove this unnecessary debris from the sewage on arrival at the works.
Anyone owning a Saniflow pump toilet know that is a very expensive mistake to put sanitary towels wet wipes etc (or unpleasant task if DIY lol)
Sewage sprayed over the ballast works as a very efficient method of treating sewage. Air and sunlight very quickly breaks it down, and very similar to the process in treatment plants. Although not pleasant for persons working on the track. Any debris chucked down the loo doesn't break down, and makes the track look a rubbish tip.
Given the issues with smells in carriages, and septic tanks not being emptied often enough (we've all had this happen). And given that other professions have to deal with human waste (such as plumbers and sewer engineers) and have developed ways to manage that risk, is it perhaps the case that poo on the track is the lesser of two evils ?
Zoidberg
27 Aug 2010
West Midlands
An alternative could be that when the built-in tanks are full, they overflow to the tracks (but not while in a station).
Fair point - although I understand that is the Mk 4 system, which according to some on here seems to be even more problematic than the traditional drop down loo !
Flamingo
26 Apr 2010
Maybe some system that allows gradual emptying whilst in the middle of nowhere travelling at speed...
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
Are you about to suggest a new thread in which we all get to nominate these places where we'd most like to have all passing toilet tanks being emptied?
I'm thinking of a few places where a regular 'dump' wouldn't make much difference.
starrymarkb
4 Aug 2009
Exeter
The 159s were fitted with retention loos from new, I believe the ones being retrofitted to 158s are a reverse engineering of the 159 loo. Certainly Wabtec had to use a 159/0 bog as a template for the 159/1 conversions.
455driver
10 May 2010
Before the pedants jump on this-
The 159s were built as 158s (without tanks) and then sent to Rosyth for conversion to 159s (1st class, tanks installed etc) so although they entered service with tanks they were not actually built with tanks.
A 159/0 was ripped apart so they could measure it and sort out the 158 and 159/1 installation.
Any modern installation should use vaccuum so it doesnt use as much water as the SWT installation does.
Peter Sarf
Croydon
Is it the case that the vacuum is why the sign says do not operate while seated and why the flush button is behind the lid (so harder to find than the emergency alarm). Might help with constipation though :lol:.
Moonshot
10 Nov 2013
Maybe the answer to the whole issue is to have trains that dont actually have loos.....buses and trams dont....
