How's that calculated? I've heard others argue the opposite - what's being included in the costs?
The big costs for underground train lines are Underground stations, remove the stations (by having them on the surface or fitting then within the diameter of the tunnel) and the cost is significantly cheaper.
It's why Musk building big spaces for Tesla's to load/unload when saying that he can create a "metro" solution for less than normal rail options is going about it the wrong way.
I have wondered if we would have been better off building high-speed rail earlier. I suppose the best time would have been after the failure of the APT project in the 80s. Leaving the WCML to solder on in the state it was for another 20 years is rather astonishing looking back. I suppose a London-Birmingham-Manchester high speed line, designed in the 80s and opened by the year 2000 would have been great, but then you'd run into the current problems. Namely; approaches to city centres getting filled up with suburban trains and these TGV type trains. So you'd either have to extend, what would inevitably have been nothing more than an LGV into and through city centres or live with the congestion.
I expect this is what an earlier British high-speed rail network would have looked like if it was planned any time between the 80s to the early 2000s. So perhaps there is no time like the present to build high-speed rail
Even if there was a need to pay a lot to upgrade city centre stations now, there would have been 20 years of higher rail growth to justify the expense (which would be lower than a mega project like HS2 as well as being much lower risk).
By far the best idea - would also knock some of the cost off building the stations and would only require very short extensions of existing platforms as an 11 car Pendolino is 275m and smaller stations can use SDO.
Capacity to Birmingham and Manchester can be exactly the same as planned by having 4tph to each instead of the planned 3tph, and everywhere else would have a lot more capacity than is planned on HS2 as their trains would be 1.5x the length.
I get it as 265m for the 11 coach 390's.
However I refer you to my last post in this thread:
Existing 9+11+11 coach trains taking 5 hours would require 155 coaches
"Javelin+" with 12 coach trains taking 4 hours would require 144 coaches
"80x+" with 16 coach trains taking 4 hours would require 192 coaches
HS2 services with 16 coach trains taking 3 hours would require 144 coaches
Whilst that's the same as the "javelin+" trains they would have 480 seats compared with 1,100 for the HS2 services.
Even if we matched the speeds, so you needed less rolling stock, if you tried to add the Eastern Leg there's a good chance that Euston couldn't cope with a 33% uplift in service provision for the shorter trains to provide the same capacity.
That either means another rebuild to fit in more platforms or turning some services back at OOC or finding another location to serve (Heathrow maybe) but with the cost of that (and the inconvenience to those wanting to go to central London) or building HS East sooner.
