Thanks
@Iskra.
Quick update time then.
I’ve been working on the south end extension this last week (the Exeter end).
If you’ve read the more recent posts on here you’ll know that when I originally built the Lapford section it stopped at the bridges either end of the layout and I’ve since added the extra fold up boards at each end to finish off the front of the layout in a better way.
Fair play if you’re still following me banging on about it by the way.
I don’t like sharp curves on a layout which is why I try to hide them as much as possible by using trees and bridges etc. Sometimes curves can be a feature if they’re done right and look like they’re following the contours of the land which is what I’ve tried to do here.
So after doing all of the grass again, finishing the trees and doing various other jobs I’ve toned the greenery down by airbrushing some earth colours over it and I’m fairly pleased that you can’t easily tell which the new section is (basically everything past the bridges in the foreground).
I’ve also tried to disguise the road going into the backscene by using (yes you guessed it) more trees and a corner:
The lane:
And here’s a couple of photos of a 33 heading towards Barnstaple with some cement wagons. I’m calling the river bridge ‘Dead Tree Bridge’ at the moment...
Quite pleased with this to be honest:
I still need to work out what I’m going to do with the backscene. I bought a load of blue card just to use temporarily but I think something will come to me at some point if I don’t rush it.
So there you go.
Thanks as always for reading and commenting on it. I really do appreciate it.
