Whistler40145
I'm sure Stockport to Ashton Moss North Junction would be a good backup route if the route via Manchester Piccadilly was unavailable, but not sure of the line between Denton to Guide Bridge.
The track diagram certainly explains the curious arrangement, although the reason for arrangement is even more puzzling particularly as the two points in the "loop" are virtually back to back.
Looking at the a picture I posted in Jul 2014 of the Olive Mount Junction to the Bootle Branch it is noticeable the steel work extends across all three running tracks for a short distance although I think the wiring only runs to the first or second piece of steelwork. I seem to remember somebody commenting in these forums that this was a common procedure presumably done to minimise disruption with a view to possible further extensions. Bearing in mind the Bootle Branch is on the Merseytravel plans for electrification and restoring a passenger service to the route it would seem a sensible idea to construct the wired junction at the this stage, irrespective of the issue of intermodal trains using the Branch. The requirement for this, one way or another will really only become apparent post 2016/2017 when volumes and inland movements can be properly assessed.
Whoever added it to Network Rail's document (previously linked) put the same:
"Work has started to modify bridges between Manchester Victoria and Guide Bridge to Stalybridge, which will be fully electrified by December 2016."
Whoever added it to the wiki page put 2016. Phase 1?
http://en.m.wikipedia.org/wiki/Northern_Hub
The unit is 319362 and is at Allerton, arrived early Tuesday morning, travelling north during the night, so no one could see it! As yet no Northern Rail branding / decals etc have been put on it. Unit 319363 left Allerton depot same time and went to Wolverton for similar refurbishment.Another step forward:
http://railnews.co.uk/news/2014/12/04-new-electric-train-for-northern.html
It is a fairly common practice to wire up the Electrically dead lines into a junction.
Take a look at the Leeds and Normanton lines South of Colton Junction near York.
Usual distance is a 100 or so metres.
The unit is 319262 and is at Allerton, arrived early Tuesday morning, travelling north during the night, so no one could see it! As yet no Northern Rail branding / decals etc have been put on it. Unit 319363 left Allerton depot same time and went to Wolverton for similar refurbishment.
I think 319 362 is now at Allerton.
I thought it was 319 380 that left Allerton for Wolverton which is now a Northern unit rather than one on loan
Also there are some pictures on the Northern Rail website I believe.
Indeed, this makes sense. One of my puzzlements, however, remains that only one of the lineS, ie the West-to-North line has been wired, North-to-West hasn't and doesn't seem to have provision for being wired, notably no masts or long arms on cantilevers or portals.
My brain still hurts.
Accidental mis-routeing of an electric train will probably have been risk assessed as only likely or possible in the one direction, west to north as you describe it. Coming the other way the route from electrified to non-electrified line may be over a much lower speed junction and the driver of the EMU might be expected to be able to stop if wrong routed.
Sorry, its called a typing error! No it was 319363 that went south, confirmed from "within" as I've said, it went down to be refurbished. As far as I am aware 319380 is only and remains on loan for driver training. Also 319361 is still around too.
In the meantime, here is the link on "Northern Rail" - http://www.northernrail.org/northern/electric-trains showing some images of the refurbishment of 319362.
HTH.
Looks like a collision in the possession last night? Picture on Northwest Sparks Blog.
No trains St Helens Central / Wigan.
Quite a bit of progress since Monday.
There are 3 wires over the M57 bridge, 2 on the north side.
They stretch about a mile either way, and one reaches to Huyton Jn.
There are 6 big mast bases now visible in the gaps in Sankey viaduct.
There are 2 ttls erected on P1 at Earlestown.
Just had a quick visit to Huyton Station about an hour ago - see images 120 to 124 via this link of current state of play - http://picasaweb.google.com/104517932653927762904/LMElectrificationWorkMerseyside2014 (scroll down please).
In the meantime, as others have observed there is three (top) wires in place between Huyton Quarry and Pottery Lane Bridge, Whiston. Either side, no wires at all.
Progress in Manchester is all the more striking for not having been for a while. I know nothing of wiring being connected up, but if wires up were the sole criteria it would now be possible to drive an electric train from Eccles to Salford Central. There wouldn't be any means of alighting, but I'm sure you get the point. Three wires are now attached to the masts immediately west of Manchester Victoria. I suspect someone reported this recently, if so, apologies.
I reckon you could work a train up to alongside Manchester Exchange, if it still existed! There are certainly more wires in that area.
You probably noticed that the Perspex roof is up over the southern section of the new structure at Victoria, making the concourse a bit drier than it was.
You can also now make out all 4 platform faces of the new tram stop.
There were big open holes at the east end of Victoria through platforms, getting ready for masts I expect.
Indeed, re Manchester Exchange, if anyone thought it was a right hole, it is now!
The construction work is for the 101 Embankment office block development, on the site of the old Exchange station. See http://www.askdevelopments.com/projects/details/10792Ending up on the ATW service into Manchester from Earlestown today, I caught the shuttle bus from Oxford Road to Victoria.
As we passed the basement of the old Exchange station, it was clear a lot of construction work was going on to the structure there.
I'm not at all clear what that is about.
The construction work continues alongside the railway viaduct up the approach road to Victoria.
