Paul Gaskell and I did a Lime St-Roby-Wigan NW-Huyton-Man Vic-Rainhill-Lime St railtour today.
Good news:
1. We confirm that a vertical pair of wires runs across Huyton Hey all the way past the Vee of Huyton Junction. There is therefore definitely a wire from Lime St to Manchester Airport.
2. A wire is up along the Ince Moss Chord (aka Bamfurlong branch) as far as can be seen from a train passing along the Wigan Branch.
3. A wire is up over the southbound line from a few yards south of the Vee of Springs Branch Junction to the previous northern limit a short distance north of Ince Moss Junction.
4. Apparent progress with masts on the west side of the Vee of Springs Branch Junction, but the situation is complex and hard to track as the only vantage point we can find is a moving train.
5. Significant progress on the three pairs of masts at Rainhill which used temporary fixings. All three look well on the way to being finalised.
6. Visible progress on reinstating the stonework atop Sankey Viaduct.
7. A wire is up ("Return Wire"??) to the north side of the track through most of the section of Platform 5 at Man Vic which is under the overbuilding.
8. More work has been done on the mystery fixings attached to the latticework above the middle of Platforms 3 and 4 at Man Vic, One such shows how the end product will work.
9. Purple temporary fixings are in place over the eastbound track along most if not all of the stretch between Roby junction and the Henry a couple of hundred yards east of Huyton station. They give the impression that things are ready for lifting a wire up, maybe tonight.
Work in progress
10. No metal danglies above Carr Mill Viaduct or the Wigan Branch M57 bridge, wires suspended by webbing and pulley wheels.
11. There are quite a few places around the project where temporary fixings are in place. It is difficult to quantify them or give an exhaustive list of locations. The good news is that a widespread sprinking gives the opportunity for simultaneous fettling by the massed ranks of Orangemen and cherrypickers visible all over the show.
Disappointment
12. Roby lifts not in use, no signs, no explanation, just not in use.
13. Huyton entrance blocked off, no signs, no explanation, just not in use.
Photos later
