0616 will be the first. 0516 remains a 156. All due to driver establishment levels and inter-working of diagrams.
Before I conclude this, I think youll also agree that we should also mention Phil Wielands parallel webpages NW Sparks with its excellent live track signalling diagrams.
Paul,
pdg1949
However, Im sure youll agree that I cant let this opportunity pass without acknowledging the fantastic input from LDECRexile Dave - in the form of his highly detailed and comprehensive photographic record of Electrification in the NW, which some of us have had the privilege and generosity to contribute to, embellished by informative, inclusive text with the occasional slice of humour added.
Before I conclude this, I think youll also agree that we should also mention Phil Wielands parallel webpages NW Sparks with its excellent live track signalling diagrams.Paul,
pdg1949
I'm hoping to be on this one on the way back!Blush!
Stuck in work tonight, I'm afraid, so no chance of making the first runs, but I might go for the first electric train to call at Huyton, at 08:40. (If I've got the workings right.)
Cheers,
Phil
Still dark in Lea Green 0615 ...a four car rather quiet train just went past the back of our house...
They're here!
319363 just pulled into St Helens Junction bound for Manchester Airport.
They're here!
Todays runs are...
319362
1H43 07:16 Lime Street to Manchester Airport
1F93 08:40 Manchester Airport to Lime Street
1H40 14:16 Lime Street to Manchester Airport
1F90 15:40 Manchester Airport to Lime Street
1H43 17:13 Lime Street to Manchester Airport
1F93 18:40 Manchester Airport to Lime Street
319363
1H42 06:16 Lime Street to Manchester Airport
1F92 07:35 Manchester Airport to Lime Street
1H45 09:16 Lime Street to Manchester Airport
1F95 10:40 Manchester Airport to Lime Street
1H48 12:15 Lime Street to Manchester Airport
1F98 13:40 Manchester Airport to Lime Street
1H41 15:16 Lime Street to Manchester Airport
1F91 16:40 Manchester Airport to Lime Street
1H44 18:14 Lime Street to Manchester Airport
1F94 19:40 Manchester Airport to Lime Street
Yippee!
Dare I ask the question....?
Excellent info, warm thanks
Just back from a 06.21 Wavertree-Manchester Airport return trip. Everything went well. On the return trip the train was held for 5 or 6 minutes at Newton - le - Willows because it had got ahead of time.
Being off work and Whiston Station around the corner, went to record my first electric passenger train on the L&M line - 319363 on 1H45 09.16 Liverpool Lime St - Manchester Airport, while 30 seconds earlier 319262 wizzed through on 1F93 08.40hrs Manchester Airport - Liverpool Lime St.
Certainly 319363 made very light work of the incline and definitely much faster going through than the usual Class 156. Well, it has only taken 185 years to get here but it has finally happened. You will note both Class 319's are in the image with 319362 in the distance.
Brilliant!, shows 319 performance IS better than 156s and 150s! ... it will be good when the timetable is tightened up (in May?), by the time they reach MIA it could be a saving of 12-15 mins?
Possibly a harder question to answer: with the 319's replacing a couple of DMU's on this service when are other services likely to see that stock appearing to strengthen them? Will they be in reserve still on this route for a while in case of any problems with the 319s or will they be deployed elsewhere quite rapidly?
