Northern Class 195: Construction/Introduction Updates
Spirit555
8 Oct 2017
Not as yet. Only delivered to Edge Hill a few days ago I believe.
Seen at Edge Hill at 1815 tonight hooked up to 08790.
Mark
Chorley Cake
23 Aug 2014
If it’s like the other more recent arrivals it will be out accumulating mileage within the next ten days or so, and in service by the last week of the month.
alm37
16 Jul 2020
York
Out on its first day of mileage accumulation to Carnforth this morning.
superkev
1 Mar 2015
west yorkshire
After what seems like years under construction I believe the new Newton Heath 4 road maintenance shed is now in use at last. I'm not sure I'd it replaces or supplements the existing facility. K
175001
3 Feb 2007
Between Heaven and Hell
It will be mainly for the 195s but can be used for the legacy fleet to take pressure off the main shed
Roger B
16 Jun 2018
Gatley
Does anyone have an update on 195021? I've been checking on RTT (not every day admittedly), and it hasn't been allocated yet. Is FFR still continuing? Have any issues been identified, any ideas when it might enter service? It would be great to know the latest position if anyone's in the know, please - many thanks.
Chorley Cake
23 Aug 2014
I think it is at Allerton depot right now. I’ve been following what I think are the daily mileage accumulation runs and this is where it finished up yesterday afternoon. There appears to be nothing allocated today.
As the number has been obfuscated all of this could be utter wibble of course, so don’t see it as 100% guaranteed.
172007
2 Jan 2021
West Mids
With issues surrounding the Class 196 introduction, does anyone have a list of C195 issues past and more importantly presentm Interested to see how being very simular the class's are how CAF have managed not to learn any lessons.
Nymanic
6 Jan 2014
Manchester
I'd like to think ride quality would be high on the list, although this is more of an issue for the 197s (which will run longer distances).
Pretty sure the bogies are identical, though, so I expect to be disappointed. The ride is woeful, such that I'm hoping it doesn't shorten the units' life expectancy.
Domh245
6 Apr 2013
nowhere
Two things to bear in mind: Firstly any major design issues will have been too late to be resolved based on the 195s - the first 195s were entering service in mid 2019, around the same time as production would have been beginning on the 196s, and the design finalised (barring easy-change things like interior fittings)
Secondly, any issues that are a consequence of being built(/designed) to a cost won't be resolved easily, especially not post-pandemic, and that's before any consideration about how much it is impacted by point 1.
Efini92
14 Dec 2016
Hot axle box sensors are faulty.
Windows and glass cracks due to vibrations.
ASDO doesn’t always work as it should.
Ride Quality is awful.
Engine oil is also used to cool the gearbox so if the engine is out the gearbox has to be isolated.
Units can’t coast at a constant speed, as soon as you shut off power the gearbox will retard, meaning power constantly has to be applied.
CCTV cameras have all taken in water rendering them useless.
AWS bell is 97 decibels.
Cab doors come open whilst the train is moving. This issue stems from when they were new the only lock on the door was in the mid point making it impossible to open from ballast level.
The PASS COM covers are so flimsy passengers set them off by accident. If the mushroom is reset anti clockwise the mushroom comes off in your hand.
There’s too many faults with the TCMS to
List.
The windscreen wipers don’t work properly (though there is a mod for that)
PIS has about 30% chance of working as it should.
They’re just the ones I can think of off the top of my head.
skyhigh
14 Sep 2014
List.
Other than that they're fine though, right? :lol:
bengley
18 May 2008
List.
Are the cab doors sealed properly when they are shut, though?
Efini92
14 Dec 2016
No, some you can actually stick your fingers through the gaps.
Because they’ve had to put an extra bar and locking mechanism on the bottom of the door the hinge bolts have been torqued to death and twisted the door.
Ha ha well they were until the yaw dampers started falling off.
bengley
18 May 2008
Exactly the same as their 125mph pointy nosed brothers then.
The wind noise is dreadful.
skyhigh
14 Sep 2014
That makes sense- I signed 195s in relatively late so I didn't experience the original issues (but I'm very aware of the current issues you list!).
Efini92
14 Dec 2016
At least CAF are consistent then.
I don’t sign them anymore, have they sorted the AWS issue out yet?
newtownmgr
2 Jan 2011
List.
As regards the units not coasting. It’s not a fault. It’s due to it being a mechanical ZF gearbox. We have the same with our 172’s. Just keeping them in notch 1 or 2 will maintain speed. Obviously with the CAF units (can only speak for the 196’s) they only have one power notch after that it’s variable power so will be a case of judging how much is needed to maintain speed.
Efini92
14 Dec 2016
Sorry i didn’t mean it was a fault, just poor design.
Do the 172’s not have a fluid coupling?
Llama
29 Apr 2014
It'd be nice to know. Any technical questions on these units might as well get met with a "don't you worry about that, sunshine".
At least that would be a response.
Efini92
14 Dec 2016
It didn’t help that the people in charge of commissioning/training on them were only interested in paying 45% tax and having a jolly for 18 months.
172007
2 Jan 2021
West Mids
ZF mechanical box still has a hydraulic coupling in lei of a clutch plus gears for 6 speeds.
The bus version has a retarder feature. Not sure if the rail version has one or how the current version works.
K
As far as I know on a 172 it's fluid until 15mph then all other gears are clutch. They certainly don't coast but slowly slow down. When coming to a station and it changes down to the lowest gear at just under 20mph you sometime have to dab extra brake as you have lost engine braking. Some are better than others in the respect.
37057
3 Jul 2009
ZFs as fitted to buses (for years now) have a lock up clutch which by-passes the fluid coupling function. I think this transmission is essentially what's in (or similar) 172s etc > ZF in a bus
Fluid couplings transmit power from engine to transmission (obviously) but also allows it the other way around too and BR DMMUs had a free wheel to prevent that.
Advantage of the free wheel - Good for coasting... Disadvantage - Engine idling (fuelling).
Advantage of lock-up clutch - Saves fuel as engine becomes driven rather than driver... Disadvantage - Coasting capability reduced.
Voith turbo transmissions 'free wheel' as the converter / couplings drain.
