RealTimeTrains website
Route115?
26 Jun 2021
Ruislip
Browsing through RTT recently, I couldn't find any trains between Aylesbury & the depot & stabling sidings? I don't know if thee are similar examples elsewhere. Why is this? Are movements treated as local shunting movements so will not appear?
I believe Aylesbury is one of the few places where the latter is exactly what happens. Sheffield and Hull are other examples.
From what I recall (someone with local knowledge should be able to confirm and elaborate on this) Chiltern have a dedicated controller based at Aylesbury who manages all the shunt movements locally according to what is required on the day. I guess this is a result of having a very compact depot where a substantial amount of the stabling is elsewhere in the wider station complex.
I’m not sure if there are base paths present locally for use on the elusive “perfect day”.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Did this site allow more than 7 days back checking?
Trying to find working at White Hart Lane for 23 Oct and 6 Nov last year between 1800 and 2100
Thanks
If you go to the RTT home page and look at the calendar shown to allow you to select a day, you will see the dates more than 7 days prior to the current date greyed-out.
This is because the station/location search only works 7 days back. However individual schedules can still be viewed going back considerably further than this, provided that you know the UID in question.
gazr
24 Mar 2014
Is the option for historical working with a subscription of some kind still on the table for RTT? I have been very lackadaisical in putting my notations into a spreadsheet, and using other sites have managed to go back to around September 2019 (luckily I record the headcode and UIC of each train I'm on). I'm mainly after the actual arrival/departure times as I don't record these on the day. Obviously I need to go back further than that, but wondering if any sites still have the information achieved or not as it must take up quite a bit of storage. I know I should use railmiles, but I'm set in my ways.
jnjkerbin
25 Apr 2012
Down south
http://charlwoodhouse.co.uk/rail/liverail has 3 years of historical data.
_toommm_
8 Jul 2017
You could always try a subscription to railmiles. I put my trips in in advance, then it auto updates with actual departure and arrival times vs. planned, along with the unit(s) if it’s currently a part of know your train on RTT.
Triumph
5 Dec 2011
Both Chiltern & Northern unit diagrams have all the ECS working shown at Aylesbury and Sheffield.
The only places that don't have the ECS working in the unit diagrams are EMR Nottingham to Eastcroft Depot and Hull BG Depot ECS moves (Northern/Hull/TPE)
Nottingham is all done by local moves as all the ECS coming out has to formed correctly for stabling in the Platforms as most of the sets are 5/6 different units.
Hull is alll done locally however the station working book does contain the movements and platform stabling plan.
gazr
24 Mar 2014
Yes, there is. It will be going into development soon.
Great news, Tom- pretty sure I'll be signing up for that. Out of interest, have you saved all the data since the inception of RTT, or does it only go back a certain amount?
Tom
19 Jan 2008
35,000ft
There is data going back to mid 2016 reliably, prior to that it's patchy in places but December 2012 I think is the earliest I have.
gazr
24 Mar 2014
Looks like I may be in luck then :) Thanks for the quick reply.
william.martin
18 Oct 2022
Telford
Probably an error with the data feed although last year it said that 390122 was working an Avanti service to Shrewsbury however the line isn't electrified!
50p says it worked it to Crewe and the service was either terminated there or there was a unit swap.
SuperLuke2334
23 Oct 2021
Welsh Marches
Wouldn't have gone to Crewe. Would have gone via Wolverhampton!
Is there more companies planned to join Know Your Train in future?
hexagon789
2 Sep 2016
Is the website down at the moment?
Working fine for me. I've tried a station search, headcode search and unit number search.
Also tried choosing a service from a station list.
All loaded no problems and I used RTT a few times earlier today, again without issue.
Looks like an issue at your end I'm afraid.
Class15
30 Dec 2021
North London or Mildmay line
Seems fine to me
Guess so. Tried it with another device and working fine.
