RealTimeTrains website
gazr
24 Mar 2014
There are some really weird ones out there, ‘Gospel Oak Mansfield Road’ being my personal favourite. No idea why that kind of thing is still there to be honest.
HBF is my favorite: Hever (Stick Hill Phone Box/Brocas Farm). Middle of nowhere. There are lots of RRB stops that have pub names in them as well.
phil1960
28 Nov 2008
North London
Apologies if this is in the wrong category.
I'm assuming RTT pulls the miles and chains data off Network Rail systems along with timings etc. Is there any reason why that doesn't always for some trains?
An example it doesn't is this one (1S12 10:30 KGX-EDB) - https://www.realtimetrains.co.uk/service/gb-nr:C71544/2025-02-12/detailed#allox_id=0
Whilst one on the WCML (9S54 08:40 EUS-EDB) does - https://www.realtimetrains.co.uk/service/gb-nr:C50099/2025-02-12/detailed#allox_id=0 (NOTE: links may not be active indefinitely)
I thought it might be the distance, but the Euston route is longer. It's nothing to do with the TOC as other LNER trains appear with the mileage data.
I know I can use RailMiles Mileage Engine, but even for a KGX-EDB that won't work as one enquiry as it defaults to the shortest route which is bypassing York station platforms. So you have to double check the route it returns and if necessary, split it up into smaller sections then add it up.
Thanks.
takno
Thanks.
It isn't pulled from Network Rail systems. I believe RTT compiled it all themselves
duffield
31 Jul 2013
East Midlands
Thanks.
I asked about this before, earlier in this thread.
Quote from reply:
if RailMiles doesn’t know the location of all timing points then it won’t show the mileage. They do run slightly different databases though. In addition, if the mileage that RTT calculates works out to a speed faster than the pathed speed it will also eliminate it.
Link to this post:
Discussion continues before and after this post.
phil1960
28 Nov 2008
North London
Quote from reply:
Link to this post:
With thanks to duffield (post 2284) and takno (post 2283) that has thrown some light on it. In the example King's Cross to Edinburgh, by doing a random search for a train Kings Cross that terminates at Newcastle that shows miles and chains. Look for a train that starts in Newcastle and terminates in Edinburgh there is no miles and chain data on a RTT search.
I'll email RTT to see if they can fix it. But no doubt there are examples of other sections of line across the country that have this discrepancy.
Phil
Aviator88
22 Oct 2012
Phil
I have never seen distance information on RTT, including in the example provided above.
I'm curious where it is situated? Thanks.
duffield
31 Jul 2013
East Midlands
It's the first column in "detailed" view but it only shows if you have a wide enough screen. On my mobile it doesn't show in either portrait or landscape view, but it does show up on my laptop and desktops. It doesn't show for future trains until around 2pm** the previous day and as discussed only for certain routes.
** From memory, I think that's the time
Image description: Screenshot from realtime trains showing mileage column for sample service from St. Pancras to Nottingham
Aviator88
22 Oct 2012
Interesting, thank you! Desktop mode when required then.
pokemonsuper9
20 Dec 2022
Greater Manchester
On my phone it doesn't appear in the default view, but when I switch to desktop view (still on my phone) it does, so it might be device dependant rather than screen size?
duffield
31 Jul 2013
East Midlands
Sounds like it might be both. Screen resolution in desktop mode is definitely relevant - if I take my laptop browser out of full screen mode and reduce the window width by about 1/3, the mileage column disappears. But maybe using the mobile view on a phone browser always hides the mileage, regardless of resolution.
Kite159
27 Jan 2014
West of Andover
Phil
With the ECML, I think it's Reston which is causing the issues.
takno
Would make sense. The station got a new TIPLOC, and that replaced the old Reston timing point in the schedules. East Linton is also a possible, but I'm fairly sure it isn't a timing point on any of schedules that don't stop there.
chrisjo
18 May 2024
Cymru
If I gradually make the window narrower on my laptop, the distance column disappears at the same time as the font switches to a smaller size at 1540 pixels window width.
800Travel
3 Nov 2023
Some LNER Services haven't seemed to show the allocated unit yesterday or today.
The image below shows a sample of services found at this link (https://www.realtimetrains.co.uk/se...9/0000-2359?stp=WVS&show=all&order=wtt&toc=GR) for departures from Edinburgh today.
The ones with units showing as allocated display a 9 on the right hand side. The ones with no 9 do not show an allocated unit, and therefore require us to backtrace to the depot run, for which units are allocated.
Unsure if this is an issue with the data coming from wherever it comes from, but thought I would flag in case it's an Realtime Trains issue.
ExRes
16 Dec 2012
Back in Sussex
A question if I may, RTT shows Hanson & Hall as having a TOC code of YG, however if you enter that for a search it comes up as not vaild, a minor glitch on the site or with me?
Thanks
LA50041
20 Feb 2017
Is there a data issue with RTT and Railmiles? Railmiles can’t seem to pick up any journeys I made yesterday 15th March
OscarH
15 Sep 2020
Crawley
I seem to recall there's an issue that relates to day T-1 explicitly. So from tomorrow yesterday should work, and it would have worked yesterday, but won't work today
LA50041
20 Feb 2017
Thanks. I’d never heard that before, but will give it a try tomorrow.
tfw756rider
30 Nov 2024
Wales
More 756s (10) than 231s (8) were in service on the 17/3/25, but the 8 231s had unit illustrations on Realtime Trains / Know Your Train, whereas the 10 756s did not have them. Are 756 illustrations on their way?
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
I'm not sure why they don't just use the 231 ones for the 756/1s. I appreciate the 756s have an extra door but it's hardly that noticeable. I mean, the 165 drawings are technically wrong (the weeny window in between two full size windows is shown at BOTH ends of a 165 rather than just the non-first class end) also, and no one has a problem with those.
Tom
19 Jan 2008
35,000ft
There's quite a large update to RTT on the way in the next few days that fixes some of the issues we've had around deployments which should hopefully resolve some of the missing graphics issues mentioned above. Can't promise all of them, but we'll be able to increase our release cadence again.
tfw756rider
30 Nov 2024
Wales
Just to acknowledge that I've read your reply :)
Many thanks Tom, looking forward to it! I appreciate RTT very much :)
