South Wales 'Metro' updates
MikePJ
10 Dec 2015
So what do these very long timescales mean for the introduction of the 756s on the Rhymney line? Also 2026 is several years late rather than the original several months delay announcement.
The timetable change this coming June will reshape the Rhymney line timetable, with Coryton trains serving Penarth, and a new Penarth-Caerphilly shuttle. TfW explicitly said when this was announced that the plan was to run these services with existing stock. However, once the wires go live from November 2024, I would expect to see those services transition to 756s - possibly in dribs and drabs as drivers get trained up, much as we saw the 231s introduced on a few diagrams to begin with and then gradually scaling up.
Charging for the Caerphilly shuttle units?
Yes, exactly. It just amused me to see a three platform station with just the bay platform wired - and the wires not continuing to the main line. I recall some discussion of whether similar short sections of wiring would ever be provided at terminal stations on the Greater Anglia network on the basis that their 755s could avoid running their engines during turnarounds, but of course that wasn't worth the investment.
Hwnt52
12 Aug 2016
Cardiff
Yes, it’s a great reference for those of us following the project closely.
I’m slightly surprised that the wires don’t start again immediately north of Caerphilly tunnel and that the line through Caerphilly will remain unwired.
I guess the reason as usual is money. There is a low bridge at the west (Rhymney) end of the station which would be expensive to deal with, so the wires will start immediately beyond the bridge.
Last Hurrah
17 Jan 2023
Canton
Well maybe an 18 month overrun . . .
I seem to recall the project had to be delivered by Dec ‘24 as a condition for the EU funding element to be made
Covid along with unforeseen issues were encountered which have delayed delivery of the project - in order to avoid the risk of losing the EU funding, the EU funded “bits” were re prioritised to ensure they were completed before the Dec’ 24 deadline
AdamWW
6 Nov 2012
Yeah, the fact that wiring is provided to the bay platform only is certainly novel!
And with a little gap under the footbridge.
Makes sense.
Presumably pantographs would only go up when stationary, which might explain why there just seems to be a gap rather than a permanently earthed section under the footbridge.
59CosG95
18 Aug 2013
Between Beeston (Notts) & Bedlington
Makes sense.
The map in Appendix A seems to suggest that it'll be a Fixed Overhead Conductor Bar at Caerphilly; ditto with the stabling at Treherbert & Rhymney.
The exile
31 Mar 2010
Somerset
Unless you mean that the wires over the bay platform track are an electric island usable only for charging battery trains, it sounds similar to what pertained at Walsall (and Springburn?) for many years.
MikePJ
10 Dec 2015
Yes, that's exactly what I mean - there's no way that a conventional electric train could make use of the overhead, as by the time it's gone 100 metres it's already dewired!
Last Hurrah
17 Jan 2023
Canton
Does the City Line service revert to being a standalone service between Radyr & Central ?
save for the am/pm through trip for the school kids ?
AdamWW
6 Nov 2012
The last I heard, the eventual plan was for 2 trains per hour each way from the Valleys through Radyr to loop through Cardiff via the City Line. And Coryton services will be going to Penarth
(I think though it's been suggested that in the first instance the City Line will be served by trains from the Valleys but terminating at Central which seems something of a downgrade).
I doubt there that a through service even at school times will be maintained given that ultimately the two lines will be using different stock.
Given that both will still be at a half hour frequency let's hope they've thought of that and provided short connection times.
While it is somewhat arbitrary that currently the City and Coryton lines are combined, as they are the two lines in the local area with the least frequent service it does guarantee good "connections" between them.
MikePJ
10 Dec 2015
Yet another consultation has gone live - please see attached. This one relates to changing junction speeds at Queen Street as part of the changes in the pointwork required to double the Cardiff Bay line.
The Cardiff Bay Line is currently a single line from Queen Street South Junction to
the buffer stops at Cardiff Bay Station. It is proposed to double the line and install
two crossovers to enable the line to be partially bi-directional and at the same time
introduce track circuit block and use Tram Signals. During a 100-hour possession in
March 2024 Balfour Beatty Rail will be renewing the S&C at Queen Street Junction,
specifically 9454 points.
The current arrangement looks like this (diagrams grabbed from the consultation document):
The new arrangement loooks like this (changes highlighted in red):
The line marked as "3" is the stub end of the new "down" line to Cardiff Bay, but which will be blocked to trains (hence the points marked "2" being padlocked) whilst construction progresses.
  • Consultation Document CVL G1 Network Change Proposal CVLNCC012 Cardiff Queen Street 9454 points.pdf
Peter Sarf
Croydon
I saw some of this on ITV Wales last night. Interesting it was said that 95% of services will be on new trains this time next year. They must be confident that the change over will happen problem free.
I presumed that 95% of all services (passengers ?) experiencing new trains by February 2025 referred to the whole of Wales ?.
Now I can see 197s all being in service by then and 756s probably are not going to have unexpected problems. But not sure many 398s will be in service by then ?.
Occurs to me however that those passengers expecting 398s will have 756s soon (so within a year) - even if they are then temporarily replaced by 150s before the 398s finally appear. So probably do-able in a roundabout technicality way.
John R
1 Jul 2013
Note that only around half the 398s need to be in operation to run the existing frequency on the TAM lines, so the roll out of those could easily run well into 2025 and not affect that target.
AdamWW
6 Nov 2012
Would that provide the same capacity as at present, given that I think a 2 car 398 is somewhat shorter than a 150?
My understanding was that the doubling in frequency doesn't correspond to a doubling in capacity.
John R
1 Jul 2013
That’s a fair point. AIUI, the plan for the final service is to alternate between single and double trams, so in each hour 6 units would be deployed.
I’m not familiar with the current provision, particularly in the rush hour, but I’m guessing at least 4 of the 6 would be needed (so 2 doubled up units per hour) to provide adequate capacity.
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
May someone please clarify the final frequency/service pattern
As I understood it:
2tph Merthyr Cardiff Central via Cathays
2tph Merthyr Cardiff Bay
2tph Treherbert Cardiff Central via Cathays
2tph Treherbert Cardiff Bay
2tph Aberdare Cardiff Central via Fairwater
2tph Aberdare Cardiff Bay
2tph Coryton Penarth
2tph Caerphilly Penarth
2tph Rhymney Barry Island
2tph Bargoed Bridgend via Llantwit Major
is that right?
anthony263
19 Aug 2008
South Wales
As I understood it:
is that right?
Pretty much yes
Jez
22 Jan 2011
Neath
Yes i presumed that as well. But for that to happen a significant amount of Valley Lines is going to need to be on new trains.
positron
4 Jul 2023
Cardiff
As I understood it:
is that right?
It's 4tph from Rhymney to Cardiff Central the exact pattern from Cardiff to the vale is unclear but there will be 3 to Barry and 2 to Bridgend
50031
28 Aug 2013
Wasn't there an article on here that mentioned the possibility of extra services terminating at Pontypridd in additon to the 3 Valleys?
Envoy
29 Aug 2014
They really need that half hourly service on the Vale Coast Line as public transport to Rhoose for the airport is really dire. The through bus service to Cardiff City Centre via a long winded route takes 1 hour 20 minutes. The train plus 2 mile bus shuttle from Rhoose station takes around 40 minutes. You also get the benefit of the train providing a fast link to Bridgend for services to/from west Wales - which also provides a quick link between Barry & the west avoiding backtracking to Cardiff.
The real weak spot in the proposed Metro will be the City Line in west Cardiff with only a half hourly service. I wonder if they could join say a train going to Penarth with one heading to Barry between Queen Street & Grangetown in order to free up capacity to allow 4 trains per hour on the City Line?
Dr Day
16 Oct 2018
Bristol
As I understood it:
is that right?
So Llandaf/Cathays only get 4 tph direct to Cardiff Central rather than the 6 tph today? But do get additional journey opportunities changing at Queen St, and direct services to Cardiff Bay.
John R
1 Jul 2013
I can’t imaging that happening. You are trying to shoehorn 18th in each direction through Queen St and you want to introduce joining and breaking sets there? That would be a huge performance risk.
Also, think of the confusion at Central with trains for both destinations, making sure people got in the correct portion.
anthony263
19 Aug 2008
South Wales
Cardiff West Junction has been mentioned as the limitations on the cityline maybe if they do build the dive under and the circleline is completed you'll get at least an extra 2tph on the line
CardiffKid
13 Feb 2011
Cardiff
That’s from next summer - 2tph Ponty to Cardiff Bay. It’s an extra service until the 4tph to/from TAM start.
