When the new class 379s take over this route, what is expected to happen to the 21 317s that are currently on that route, probably a few too many to just strengthen services on the west anglia route?
No plans to swap some of them for FCC's 321s?
Surely if anything it makes sense to give as many NXEA 317/1s as possible (I don't think FCC would need all of them) to FCC and the 321s to IL to give FCC a uniform fleet of units they are far more used to and keep the GE outer fleet as 321/360 rather than becoming 317/321/360. The 13 FCC 321s should more than cover any planned GE 317 turns.FCC 317s for NXEA 321s? Agreed, as long as they're 321/4s!
As for the 379s, it might have made more sense to use an a.c. version of the 444, for commonality with the 360s.
The Stansted 317's are staying with NXEA and are being used to strengthen other West Anglia services (making some much needed 12 coach services)
Should see 12 car 317s heading out on the GE side for over a hundred miles though
The jigs for the 444s were scrapped after the order was completed so Siemens cannot build anymore unless they build all new (very expensive) jigs. Anybody that thinks this would be a cheap job is sadly mistaken.
I cannot believe that for one minute. If Siemens where offered a good enough contract they would bid for it in the blink of an eye.
Almost certainly not all of them, there are only a few Cambridge line services that loadings indicate require 12 cars and at least one of them should be 379s. 317s won't be fitted with SDO so where you can take a 12 car workings will be heavily limited by that.
Whether you believe it or not it is true!
Siemens probably would bid, but they would have to factor in the costs of new jigs, as I said!
There are no plans to migrate any of the Cl317's onto the GE side. If anything there will be a migration of Cl315's with some of the Cl317's ending up on WA inner-suburban diagrams and others currently covered by Cl315's (hopefully including the morning peak Hertford services that currently use Cl315's).
Even if the SDO system used is similar to the crude door cut-out switch used on the FCC units to permit them to operate as 8 car formations calling all stations from Cambridge to Royston it will be enough to allow for 12 car services to call all stations.
O L Leigh
Given that drivers have forgotten the length of their trains, hence the issues at stations like Hatfield, what safeguards are there in place to ensure a driver of an 8-car train doesn't forget to lock out the rear unit?
Put that under 'own goals'!
seen 317.882 several times this week in all over white with full stanstead express branding, not sure if it is just waiting the application of the grey or if it is remaining in this livery. Interestingly it suits the 317.
If anything a few class 317s could transfer to FCC and a few 313s join others that recently migrated to Southern.
Although class 317s are my favourite trains of that generation, I was genuinely surprised when they took over from class 322s on the Stansted Express.
It was simply a case of numbers.
There were a total of just five Cl322's, which was fine when the old Stansted Skytrain service was inaugurated because the passenger numbers through the airport was so low. However, as traffic has increased so has the requirement for more units. The current level of service requires the use of seven "sets" of units which are most often formed of two units each. This means a minimum requirement of 14 units operational at all times plus maintenance spares and so on.
All that aside, the WAGN Cl317/7 conversions offer a far higher standard of accommodation than the old Cl322's together with the added flexibility offered by having gangways throughout the train. With a few extra tweaks (sealing up the window vents and replacing the air-driven doors with electrically-driven doors that close automatically on timers) they really could be as good as brand new trains.
O L Leigh
