Thameslink/ Class 700 Progress
387star
125 first treated
Edit Appears some tl logos placed much further down on at least one 700 might be imagining it !
Domh245
6 Apr 2013
nowhere
I'm intrigued by a couple of things on these.
1) 1st class section - why does it sound like there was a strong wind blowing through ajar window when the thing gets moving, as if the anti wheel slip mechanism was using air or something.
2) from the outside, when the doors close and driver releases the brakes it makes a series of quick pah pah pah pah pah's (I know it reads silly but that's how it sounds). Why does it do that rather than a single long pssssssssh? A fault perhaps?
That's the latest equipment from Knorr Bremse (who do the brakes) and is also found on LU S Stocks and a few other modern stocks. Not sure why it does it that way, but definitely not a fault.
EMD
22 Apr 2017
Brakes made by Knorr? Bloody bean counters hahaha
samuelmorris
18 Jul 2013
Brentwood, Essex
After terminating a train at Elephant & Castle at 7pm today due to a fault, the diagram was cancelled for the rest of the day and not only that, the other late night Sutton service was also cancelled. Any ideas what happened to cause this?
Friends of mine are potentially moving to Sutton soon and the last train home being 10:40 is pretty poor...
Spartacus
25 Aug 2009
Pantograph combined with the usual 700 computer says no <( (700005)
The last Luton - Sutton was cancelled due to a defective pass-com on 700022
MisterT
12 Oct 2014
The Netherlands
I have no experience with the 700, but we have a few units and locomotives in the Netherlands do the same thing (yes, we also use Knorr Bremse).
The units/locomotives have what we call in Dutch a 'halterem' or literally translated a 'station brake' (I have no idea what it is called in the UK), which is automatically applied when the speed drops below 2 km/h.
I don't have a better picture available at the moment on my phone, so it's the whole cab instead of the gauges, but you'll get the point, I hope.
For example in our Bombardier Traxx MS2e locomotives (click for the large original size):
At the right, next to the display on the right, you see two gauges. The upper gauge is the brake cylinder pressure gauge, which is currently at 4.5 bar, which means that the locomotive brakes are fully applied.
Below is the brake pipe gauge, at the moment at 5 bar, which means that the brakes on the coaches behind the loco are completely released. This way, only the loco brakes are applied.
As soon as I apply power, the loco brakes will release automatically. To avoid the train rolling backwards on uphill stations, the brakes are not released at once, but in a few steps. This way, I can built up the traction power before the brakes are released, to avoid rolling backwards.
You can hear it in a cab ride I recorded some time ago: https://youtube.com/watch?t=0m47s&v=vxKR5eHGELA from 0:49.
Spartacus
25 Aug 2009
Pantograph problem at Elephant ? That would be highly unusual to say the least.
Faulted at Kentish town where the computer issues first manifested themselves, leading to eventual cancellation at E&C. Experience shows there's little point in keeping it in service when the AI goes US.
387star
132 has new logos much further down bodyside possibly an error or a new styling !
spark001uk
20 Aug 2010
Can't remember who it was said the 240v sockets can't be tripped, but I'm currently on 700039 (2V60) and they're all dead! ;)
bengley
18 May 2008
Typical. Couldve installed a small table
If it were my choice there would be no bays at all. Bays of seats are seriously abused by people who like putting their feet on the seats. I walked through a train one day not too long ago have had to ask twenty-four people to take their feet down.
It's disgusting and something needs to be done about it.
asylumxl
12 Feb 2009
Hiding in your shadow
To be honest, I find bays annoying for a different reason. You'll often find a 2 people sitting in them and very rarely will they move for a group of 3-4 people to sit together. If there's very few seats I can understand, but off-peak when it's more lightly loaded, not so much.
Domh245
6 Apr 2013
nowhere
I have no experience with the 700, but we have a few units and locomotives in the Netherlands who do the same thing (yes, we also use Knorr Bremse).
As soon as I try to drive away, the loco brakes will release automatically. To avoid the train rolling backwards on uphill stations, the brakes are not released at once, but in a few steps. This way, I can built up the traction before the brakes are released, to avoid rolling backwards.
Your halterem sounds a bit like a spring applied parking brake. I don't think any UK mainline stock are fitted with these, but most trams are. I assume that it is air-operated, in which case a number of our trains do something similar in that the brakes only come in at a low speed, having slowed down from the higher speed using the motors to slow down.
Your explanation for the staged brake release certainly makes sense. Having done a bit more research (googling images of a class 700 cab!) I note that there isn't a hill start button (or one that is immediately obvious). In previous trains with only a single power/brake controller, there has been a button on the desk or on the power handle which allowed the brakes to stay on to allow the power to build up before then releasing past a certain speed/power notch.
westcoaster
4 Dec 2006
DTOS A or B
700 have a holding brake that auto applies as soon as it stops. It releases as soon as the train detects a positive power/movement. Holding Brake is 40%.
MisterT
12 Oct 2014
The Netherlands
Holding brake sounds exactly like it, thanks :)
It is, by the way, definitely not a spring applied parking brake: the units and the locomotives have those things too as a true parking brake. The holding brake is air operated, which is why you can hear the sound of the brakes releasing. The spring operated parking brakes are a lot less noticeable.
Bishopstone
24 Jun 2010
Seaford
Now what's up with that hurricane like noise inside the first class compartment. Sounds as if the train was being suctioned onto the tracks when it sets off. I'm quite curious about this one.
Is it the St Albans mob descending en masse upon declassified first in the rear coach?
jon0844
1 Feb 2009
Had a 12 car 700 stop at Knebworth today, clearly testing SDO as the rear four doors didn't release. Stayed 10-20 seconds and off again.
(image of train on platform 4)
spark001uk
20 Aug 2010
I was on 112 yesterday, and under the DMCO at one end there was a fan going full chat permanently, could even be heard in the coach above it whilst travelling. I got off at ECR and as it departed it sounded like the Marston on an HST.!
samuelmorris
18 Jul 2013
Brentwood, Essex
First time I think I've been caught out by a failed unit, waiting outside CTK whilst a power fault is diagnosed. Was bound to happen eventually!
