Transport for Wales 769's
arfortune
15 Jan 2014
The 769s have been unable to run over the last couple of days due to a problem with the bridge at the south end of Queen St station and which requires Network Rail to carry out some work. This applies to freight trains also but 142s, 143s, 150s and 153s are able to run. I cn't provide any further details at the moment as I only picked it up from Facebook
TfW lead on sorting this out as it's just with the CVL. Naturally NR were invovled too due to GWML,
PHILIPE
14 Nov 2011
Caerphilly
A 769 still trapped at Rhymney due to the bridge issue which has had it's route availability downgraded to RA3 due to a weight issue. The RHTT has run, however, via Radyr, Llandaf and on to the Bay Branch before reversing to access the Rhymney Valley. The Cwmbargoed coal trains will do likewise. We will have to watch this space as 769s are cleared only for the Rhymney Valley and unable to travel via Radyr.
Envoy
29 Aug 2014
Could they not run the 769’s on the Ebbw Vale’s or Cheltenham's - and possibly make use of the wires whilst on the mainline? The 170’s perhaps could be used on the Rhymney to Penarth route?
Caaardiff
9 Jun 2019
That would complicate an already complicated situation. 170s I don't believe are cleared for Rhymney and 769s not on the Ebbw line. It would also mean starting train crew training from scratch for both fleets. By the time all that is sorted, the bridge issue should be sorted.
It would be quicker to clear them via the city line to get through. Unless there's gauging issues along the route?
Its about time the 170s are utilised better to Swansea or further. They are nowhere near utilised to their full potential. But that's a topic for another forum!
Bikeman78
26 Apr 2018
The two fuel tanks on a 769 have a capacity of 1000 litres (220 gallons) each.
Thanks for this. 500 litres per vehicle so if they are of similar efficiency to a class 150 then the fuel range is only 500 miles.
Bikeman78
26 Apr 2018
No 2000 l per rake 1000 l per dt car
Yes I get that but a 769 is roughly the same weight and length as a four car 150. Each individual 150 vehicle does roughly one mile per litre. So a four car 150 burns four litres per mile. Unless the 769s are much more efficient then the 2000L will give them a range of 500 miles.
Cardiff123
10 Mar 2013
So 769 testing & training is now on hold yet again due to problems with the Valleys bridge over the mainline between Central & Queen Street. I guess Network Rail/Keolis Amey won't see it as an immediate priority to fix the bridge problem imminently either as the weight restriction is not causing any disruption to normal passenger services (at the moment).
The 769 project seems cursed. :'(
PHILIPE
14 Nov 2011
Caerphilly
The bridge is now available for Coal and RHTT trains but with some restriction (unknown) and suggestion that 769s may be able to pass over at 5 mph. but I haven't seen anything definite on that. Probably too late for anything this week`as crews and tutors otherwise deployed
Danor97
24 Jan 2015
First Cwmbargoed should be over it Friday with inspectors in presence to assess the bridges condition
konstant
23 Mar 2015
United Kingdom
These units do not have a pantograph.
Initially it's understood these units are doing 490 miles to a tank so good guess.
Crews available every day - 003 was due to come into Canton over the bridge today but failed with electrical fault this morning and thus resides in Rhymney. Indeed RA4 and below will pass with a watchman on their booked crossings only.
geoffk
4 Aug 2010
A bit shortsighted to remove the pantograph from what was an emu. Maesteg - Cheltenham would have been a possible route, using the wires from Cardiff to STJ.
Cardiff123
10 Mar 2013
TfW RS's plan is to only train Rhymney crews on the 769s. Maesteg - Cheltenham would involve training up more crews, getting the 769s passed to run over those routes etc. The 769s were never ordered for use in Wales for their bi-mode capability, they were ordered purely to boost capacity and to see off the Pacers.
konstant
23 Mar 2015
United Kingdom
Why would a unit procured for running on an unwired route need a pantograph? It was a very sensible decision given that it adds a vast amount of risk, cost and time to each servicing event.
The unit is required to run to Rhymney - we add nothing to the project or the wider discussion by listing a list of locations they might make it to if they had a pantograph. They're not the locations the customer wants it to go.
PHILIPE
14 Nov 2011
Caerphilly
Agreed. As has already been pointed out numerous times, the four carriages are intended to provide capacity in the Cardiff Valleys and for almost the whole day they would be a waste on the Maesteg to Cheltenham route.
craigybagel
25 Oct 2012
Putting them on Rhymney vice Cheltenham/Ebbw is the difference between training about 40 crew and training 200. If they were a long term solution then maybe you could make a case, but as a short term filler until a long term solution arrives, it would be a massive waste.
Caaardiff
9 Jun 2019
4 cars would be overkill for Maesteg or Ebbw Vale, even at peak times. 3 cars is usually sufficient.
AdamWW
6 Nov 2012
003 on its way to Cardiff now as 5Z53 11+14 Rhymney Sidings – Cardiff Central. Let's see what happens at the bridge!
Looks as if it made it...Cardiff Central 12:43 (and 1/4)
Doesn't seem to have turned round to head North again as per the timetable.
Jamesrob637
12 Aug 2016
Give it a chance - two runs might be too much to ask for :D
Bob Price
8 Aug 2019
Double testing this morning with 008 and 004 out. Building up the miles. According to the schedule the last one is at destination at 10 tonight so looks like they are trying to get as much out of them as they can.
6Gtraincrew
22 Feb 2018
008 and 002.
