Wellglade Group
8 Mar 2018
I thought all the E200's had skylights. The ex Mickleover ones don't seem to have them in the photo.
Just seen 494 on the villager. Bus times shows 493 on the V3 as well.
bringiton
24 Feb 2024
derby
The first batch (101 -108) didnt have them, fairly sure the rest do from what i recall
TB no longer painting tops of buses to save on cash?
To add to this, the ex threes versas are still having their roofs painted red. So it seems to only really be something which is done on new orders, so wouldnt save that much money id think
Cesarcollie
5 Jun 2016
It’s nothing to do with money - would make little difference. Might even cost more due to masking etc and an extra colour. Will be all to do with heat absorption.
swinny1990
27 Jun 2024
Skylink scanias 662 and 663 have been withdrawn just leaves 669 left at Nottingham that will be withdrawn once 712 comes back from paint
38291018
31 Oct 2024
England
I have also seen i4, Indigo and Nines Enviros on the pits at Meadow Road. On the one hand it is a fair way to send a van from a faraway depot, but sending the local van stops them doing planned working their own fleet.
Although some indigos and i4s are based at derby as a outstation but I would assume they sometimes would take other depots buses to fix if there closer.
Sometimes red arrow coaches come off route in nottingham and head to nottingham depot, so id assume the nearest depot van, same with my15s from ema going to kinchbus depot. I'd assume it would depend on whos available to go out to a vehicle too.
Thinking about my15s going airport, why isn't the my15 'airport spec' with luggage rails as it connects the airport like the skylink or is it because it's to be expected alot of people comming of flights won't use the 15 as it is not a major route as in don't go Derby/Leicester/Nottingham like the skylink
Trentbarton use bio diesel. Presume there is also a winter grade.
As far as I'm aware i could be wrong, but I dont think that will be a problem as i would expect them to be using B2/B5/mabey B10 mixes or some similar which acts similar to conventional diesel. However the more biodiesel there is it tends to become like gel and clog up so for example B5 is better than B10 but again what temprature it freezes at also depends on what oils are in the fuel however I think it's possible to put additives in and use fuels that are processed different such as crystising the fuel to separate higher melting elements so say if B100 was used although I highly doubt it be 100% oil 0% diesel you could potentially run higher bio fuels like B10 B20 if additives are added and processes are implemented making it winter grade.
No, its a heat thing. London busses tend not to do it as well. White deflects heat which can be a big help in the summer. Not like people see up there
To be fair I've never noticed it now being white or haven't being paying much attention
Are these not going TM then I mean I haven't checked but I assume they don't meet emissions for sheffield
bringiton
24 Feb 2024
derby
With my15 mainly serving Sawley primarily and serving the airport as part of the extended route I'd assume there isn't enough passengers who would require luggage racks...and if they did they wouldn't really effect anyone since not many people are continuing all the way to the airport. When I get my15 to the airport or from, usually there's very few people around castle Donnington, especially when it's not peak flying season. The other week I was the only person on from east midlands airport till castle Donnington bus station. Alot of the time passengers who are going airport bound are going to the aldi distribution center. Mainly just passengers who wouldn't benefit from the removal of seats in aid of luggage racks
662/3 are E6, 669 isn't. Apparently they are but then it's said that 663s had parts removed and put on the trainers. So to me it doesn't make sense however time will tell
Depends the route really. Was once stuck in heavy traffic on a skylink nottingham, all the windows were open (no air flowing since we werent really moving) and it was sweltering in the bus. They obviously have painted roofs. Don't really have an example on the newer busses but having traveled on them a fair few times they definitely feel cooler.
Robertj21a
22 Sep 2013
I suspect the vast majority of passengers would rather it was Arriva who came of the X38.
Not if they want to ensure that their bus turns up!.
TrentBarton are still not running all the buses they should be (not just X38).
Passengers just want a reliable bus service, it doesn't have to try to claim that it's the really good bus service [when it clearly isn't].
30 Jul 2024
Nottinghamshire
Sutton based vehicle 850 has transferred to Manvers St, covering for the Solars, left Broad Marsh on The Keyworth at around 11:26.
I'm assuming this is temporary, and will be swapped for 712 later this month?
Trainman40083
29 Jan 2024
Derby
By then, 101 to 104 and 726 might be out . Well 6th February
derbybusdepot
17 Dec 2015
Believe the timetable change for Keyworths is on Sunday 2nd February. That will see 101-4 and 726 enter service on the route.
Bsip funds the extra bus to allow a 15 minute daytime frequency with extra running time/layover to improve reliability. I assume if it works out not to be viable longer term it will be back to every 20 minutes with 4 buses.
43055
8 Mar 2018
Wonder if the ex Ilkeston Flyers will make it onto the X38 that day as well.
derbybusdepot
17 Dec 2015
Re x38, I've heard they are being fitted with 2+1 seating, like the villager Darts were once upon a time. Imagine that on there now.
Obviously the daytime loading will be somewhat down per bus with so many running, but the night owl trips used to get very busy,not sure fewer seats will be a good thing.
Trainman40083
29 Jan 2024
Derby
So many people these days, seem to claim they don't like sitting next to another person, so maybe it will appeal to such passengers.
busspotter1
23 Jul 2024
NOTTINGHAM
Nice to see them doing something different!
PS - I like your website!
