GWR Class 165/166 Turbo Diagrams
RPI
6 Dec 2010
December should be fun around Exeter then when the 143s go with nothing to immediately replace them, 4 diagrams would then I presume see 4 2 vice 4 diagrams on the Exmouth-Paignton which at peak times now (yes, even with Covid) is extremely busy, social distancing is non existent with a 4 car, id hate to see with a 2!
warwickshire
6 Feb 2020
leamingtonspa
Isn't there one castle hst set due very soon. Just before the December 2020 timetable Change. From conversion at Doncaster webtec. Which went up middle off June 2020 from st Phillips Marsh hst Depot for conversion. Which was one off the ones hull trains had on hire from great Western last year 2019.
HamworthyGoods
15 Jan 2019
Mitigation is already in place, even before the extra HSTs were ordered there was still a spare traffic diagram and with the first of the extra sets class 158s will be cascaded to allow the planned movements of turbos west ready for 1st January.
Express380
7 Mar 2020
I read that the pacers are going on the 13th December before the timetable change and turbos will take over some workings from then is this true or not?
RPI
6 Dec 2010
Thats a relief!
windnoise69
16 Oct 2011
Bristol
1 or 2 turbo diagram on Devon metro I believe coming from the extra castle set due (Mon-Fri). Some extra 158 work on Cardiff - Pompeys
davetheguard
10 Apr 2013
I presume Turbos on Devon Metro duties will be three car sets running on their own. I also presume that you can't couple a Turbo to a 143/150/158?
cactustwirly
10 Apr 2013
Or a pair of 165s maybe?
Very much doubt that, they're being released by 1 Castle replacing 2 158s, to work a Portsmouth - Cardiff diagram.
A 2 car 165 will have close to the seating capacity of a 150+143 so it'll be an adequate replacement.
RPI
6 Dec 2010
Not so much for the summer, the issue on the metro in the summer is luggage/bikes/pushchairs
HamworthyGoods
15 Jan 2019
Yes but we are currently talking about the mitigation for the winter timetable, there will be different plans in place by next summer with further additional HSTs.
RPI
6 Dec 2010
The issue then will be social distancing!
cactustwirly
10 Apr 2013
Obviously not ideal, the 769s should have been in service by now.
But they're not, there aren't anymore turbos to release, unless you cut other services.
Social distancing isn't a huge issue as there is mitigation such as facemasks etc, and I doubt the Devon metro is rammed at this time of year.
RPI
6 Dec 2010
The Devon metro has seen more of a return to "normal" than a lot of other routes, thats the issue
Express380
7 Mar 2020
But if 2 158s can come off a cornwall diagram and go up to bristol thanks to the extra 2+4 set (05:40 Penzance to Exeter I think is the diagram it should work which is currently a pair of 158s but thats going off RTT) that surely could release at least 1 turbo
fgwrich
15 Apr 2009
Hampshire
I have a feeling it'll be some time yet before any enter service - the first one isn't allowed out with nothing else to rescue it, and at the moment it doesn't move either. It's a shame the EMR cascades wont be releasing any 158s any earlier either, as that could / would have helped the situation for GW.
cactustwirly
10 Apr 2013
It releases 1 165 and 1 166.
These are presumably being used to replace 2 separate 143 diagrams?
Pacerman99
23 Apr 2019
Third Rail Land
166209. It's currently based at Reading.
Makes a change seeing something blue back in LTV area
Absolutely! I commute on the NDL every day and really miss the 2+2 seating of the 166s both in the 'family area' in the middle coach and the declassified first section. Any ideas how long it's staying at Reading for? I presume its just temporary.
JN114
28 Jun 2005
166209 goes “home” to Bristol on Wednesday - it was only at Reading for an exam, and the exam only took a couple of days; so Bristol have let us use it until Wednesday. After it goes back there aren’t any immediate plans to have any 166s at Reading, we’ll just have 165101-165127; and they’ll have 165128-165137 + all the 166s.
The odd one may still visit, and we may or may not get to use it when it does; but the RHM mods programme is finished, so the fleet has been shuffled round to its end state, until the 769s come on stream.
Express380
7 Mar 2020
Sounds right if thats the case and the turbos come down it would also free up 2 150s as the 150s have to be with the pacers so they could go onto another diagram to make a 4 car
Rich McLean
6 Feb 2012
Well at it stands, it isn't that simple, as that pair of 158s splits at Exeter, with one going back down to Penzance, and the other set dropped off also has its own diagram back to Penzance (which also attached to another unit later in the day). Of course, I haven't checked the changes for the Dec TT change.
Apedlar12
13 Apr 2017
From what I have heard it sounded like there was some discussion about using one turbo on BNP <> SJP on weekdays replacing a 158/9 which is currently booked on there which I would assume would be used on CDF <> PMH as there is due to be some more 158s working on that route. And the other turbo would be used on EXM <> PGN but from what I have worked out that would leave EXM <> PGN with 5 double 150 diagrams and a 16x diagram so the last diagram would still need to be covered so maybe that will be short formed for a few months into 2021...
pompeyfan
24 Jan 2012
Could the platforms on the Devon metro area cope with 4 or 5 car turbos? It’s a shame that SWRs diesel SDO system wasn’t built into all sprinters and turbos. It’s primitive but works
HamworthyGoods
15 Jan 2019
As far as I was aware SWR’s 158/159s don’t have SDO but it’s a selective unit opening system. This works fine on through gangway stock but not so well as block ended stock such as turbos.
Clarence Yard
18 Dec 2014
Why would you want a 4 or 5 car? A 3 car Turbo carries more punters (sitting or standing) than a 4 car 150.
