Actually I think they're occupied with the transformer as the pantograph are in the driving vehicles. Which also means, I suspect, that they won't be all that much lighter.
IIRC all the intermediate cars, whether powered or unpowered, have the high floor that physically allows an engine underneath, but the driving cars cannot have a high floor because in addition to carrying the transformers they also have a low ceiling under the pantograph well?
Yes that's correct. You leave the DPT then go up through the vestibule to the next coach, then drop back down into the next DPT. It's quite steep.
I wouldn't say quite steep! I've walked through full length of a 5 car set, and difference in height is hardly noticeable.
Is there a on line comparison kind of like for like with a 180 Adelante?
There were a whole set of test runs on the Reading to Didcot section last night. I saw one go past Pangbourne at 7:30. There were two silver 5 car units, pantographs up and apparently running from the wires.
http://www.realtimetrains.co.uk/sea...3/05/0000-2359?stp=WVS&show=freight&order=wtt
Apparently under possession with no other trains running.
When you say "2 units", do you mean separate runs with single units, or were they double sets with both pantographs up?
Is there any significance in those tests having 5Zxx train numbers rather than 5Xxx which have been used for almost all other tests so far?Saw them over the flyover at Reading this morning.
5Z27 Wantage Rd - Reading, definitely 800002 & most probably 800001.
Returning to North Pole as 5X25, currently sat in P10 at Reading Stn as I type this.
Sounds good to me, so the only significance is that there are officially no gauging issues between Reading and Wantage Road.From the Network Rail WTT (my bold)
FOUR-CHARACTER TRAIN IDENTIFICATION SYSTEM
The number inserted in each column above the train title is the description allocated under the four character train identification system and provides the following information:-
1. The first figure indicates the classification of the train.
2. The second character indicates the destination area or Zone (see also below).
3. The third and fourth figures represent the individual number of the train.
X In the second character indicates trains conveying out-of-gauge or other exceptional load.
Z In the second character indicates excursion, military, Royal or other special train.
Perhaps in this case it is because between Reading & Wantage Rd it was running as a 'special' train I.e under test conditions but once it finishes these runs and moves back to NP, it changes to a X to signify to the signaller that it is not to deviate off its booked route.
Are we sure that that is an 800 and not an 802? I was under the impression that all of the 800s were being done in white, not to mention that the 800s are supposed to be fitted out at Newton Aycliffe, whilst that photos show slightly more than the bodyshells that you might expect to be delivered to the UK for the IEP batch.
So why were the GWR HSTs from Penzance to Paddington running as 1Zxx on Sunday?From the Network Rail WTT (my bold)
One of the first body shells for Italy. Thus 802.
It is a regular occurrence for the body shells to be moved by road from the factory to the dock for shipment. Only this move was during day light hours and subject to some local Hitachi PR. Hence the crowds.
