Are any IEPs expected to be testing in Scotland?
Testing, no.
The test sites are Devon banks, Swindon - Reading, Darlington - Doncaster and Peterborough - Grantham.
There may be some route proving once units are handed over to VTEC
Would be either 800001 or 800002, I believe 800101 is currently down here based at North Pole at present.
800101 left earlier on the 5X29 1912½ North Pole Iep Depot to Bristol Parkway.
It was then booked to continue as the 5X40 2130 Bristol Parkway to Newton Abbot but it was cancelled.
Saw 5X29 go through Reading, not long after the NR test train left p4. Was the "Azuma" one. I guess the test down to Newton was intended to compare performance results with the 5 car among other things?
I still cant understand why no 800s have been sent at least once down all the routes they are going to be used on - if nothing more than to check clearances.
That's called route proving and is done by the train operator.
Hitachi is still doing preliminary testing on the units - making sure they do what they say they would before handing them over to the operator.
If GWR are going to be doing this in house, once the units are delivered, I guess it would make sense to do it with the driver training at the same time. For example, if a set was scheduled to dop a Worcester Foregate Street run for driver training, the set could also be route proving at the same time. Especially since no IEP has ever touched Oxford let alone the Cotswolds yet, considering the plan is to put the sets on this route as one of the first and initial routes later this year.
That's not the plan. I'd be amazed if an IET makes it to Oxford this year.
The plan as of a few days ago when I spoke to a senior GWR manager is to run 5-car IET's on three of the 180 diagrams from December when the 180s head off to Grand Central. That will mean quite extensive use to Oxford and the Cotswold Line.
The plan may change, as it's changed many times before, but that is the current ambition.![]()
Will they be doing the same at all with the GWR IEPs on the ECML to compare performance?The Azuma has been doing the Plymouth and Exeter Test Runs for a while now, and yes it is to compare performance of the two 800 models, 800/0 and 800/1. As the Azuma is currently the only nine car IEP to have been released from Newton Aycliffe, GBRf are using it for testing on both the ECML and GWML.
Sorry if it has already been posted.
http://www.realtimetrains.co.uk/train/K97210/2017/03/20/advanced
Is this a Class 800 test? If so, which one?
Thanks.![]()
I have noticed this is running today, and is a daylight run, so may pop down to my local station to see it - photograph it too. No idea which units this will be but one hopes an 800004 + 800006 combo!
http://www.realtimetrains.co.uk/train/K97282/2017/03/19/advanced
Yeah, just as I imagined, my worse nightmare. Went down to Maidenhead today, weather was crap, and saw 800001 and 800002. In July 2016 I saw the same two at the same spot, same station, same order, same time, same weather. I'm bored of the lack of variation, so I'm going to call it quits. Knew GBRf would defeat me in the end.
Is this significant that Airport Jnc to Reading was completed in 10 minutes less than schedule or was it an easy schedule?
Preliminary?
The first set arrived over two years ago last week.
Someone is paying a bomb for all this testing. The stuff has been built, so money has changed hands in the supply chain, but the trains still aren't earning.
Forgive me if this has been covered but don't some of the 80x run with 2 pantographs raised and is such operation now ok for the older electrifications like. The ecml?
K
