dk1
Yes I agree. Tweets have been very vocal to XC from those using Winchester.Without much objection. Social media, particularly Twitter, would partially prove otherwise.
How many international trains would you need to coordinate apart from Eurostar, whose paths are basically set in stone anyway?
On the continent of course, having common timetable changeover dates is essential, whether countries are an EU member or not.
NI Railways (Translink) and Iarnród Éireann do not in general keep to the European timetable change dates.The international trains from Belfast to Dublin I was thinking off. If the UK moves away from the standard December timetable change it’ll cause no end of grief with the international services to RoI south of Newry.
Just been looking on RealTimeTrains and noticed a couple although I realise that whether these happen will depend on how things go COVID-wise:
- 1V17 (XC) 2130 Birmingham New St - Gloucester extends to start back from Leicester at 2018. This one currently arrives at Gloucester on Platform 2 which is that used by 1M89 (XC, 2145 Cardiff Central - Birmingham New St). However RTT shows that 1M89 will be booked to use P4 at Gloucester, rather than P2, and the next working for the unit that forms 1V17 will be 5C17 (2237 Gloucester - Bristol Barton Hill WRD).
- 1C36 (GW) (2200 London Paddington - Exeter St. Davids, via. Bristol Temple Meads, due 0112) is shown as departing a couple of minutes later from London Paddington. After arriving at Exeter St. Davids (at 0112, as at present) it then shows as continuing to Plymouth where it arrives at 0210. Same stopping pattern for 1C36 between London Paddington and Exeter St. Davids as at present but thereafter calls at Newton Abbot only and not Totnes.
Dave
Not surprising given the need to split up 769 and Turbo operation.21.30 (M-F) Basingstoke to Oxford is cut back to Reading
Good news indeed that there will he a quick London train again, although i very much doubt it will be driven by Plymouth lolOther changes, which appear to be new that didn’t run pre Covid-19 I’ve spotted on the Western are:
04.58 (M-F) Penzance to Paddington starts later at 05.05 and arrives in Paddington earlier at 09.55 restoring a 3 hour journey time from Plymouth to London, currently 3hrs 7min. One for @Irish Rail!
06.59 (M-F) Gloucester to Taunton and 09.25 Exeter to Penzance have been merged into one train (HST)
07.13 (M-F) Paignton to Paddington gains a Frome stop
07.51 (M-F) Penzance to Plymouth carries onto Exeter
10.17 (M-F) Plymouth to Penzance originates at Exeter at 08.55
19.15 (M-F) Penzance to Exeter carries on to Bristol later than the current last train from Exeter to Bristol
20.07 (M-F) Paddington to Bedwyn gains a Maidenhead stop
21.15 (M-F) Paddington to Oxford starts later at 21.20 and looses stops at Maidenhead and Twyford
21.26 (M-F) Paddington to Reading extends to Didcot Parkway with a connection there for Oxford
22.25 (M-F) Plymouth to Exeter is new
22.29 (M-F) Reading to Basingstoke and 23.00 back to Reading are new
08.04 (Sat) Exeter to Paddington originates Plymouth with new stops at Ivybridge, Totnes, Newton Abbot, Teignmouth, Dawlish, Dawlish Warren, Castle Cary and Frome whilst the current 06.52 Plymouth to Paddington is later at 06.55 and no longer calls at Totnes or Castle Cary
On summer Saturday Torbay seems to have a healthy number of direct services from London with Paignton trains at 08.35, 10.35, 12.35 and 16.35 from Paddington and 08.55, 10.56, 12.56, 14.56 and 17.01 from Paignton. All stop at Torquay, Newton Abbot, Teignmouth and Dawlish with some also at Torre and/or Dawlish Warren. The 14.36 Paddington to Plymouth and 16.45 Penzance to Paddington both stat Dawlish and Teignmouth seems to give the Torbay stations a nice 2 hourly London service more akin to ‘the old days’ still only one XC service each way calling at Dawlish and Teignmouth though and that only runs to/from Bristol with the working to arriving early evening with no morning service at all southbound!
On Sundays the current hap-hazard local service from Penzance seems to have been standardised at 50 past the hour from Penzance.
Some positive stuff especially for the West Country it seems.
It won’t be on there yet. Still way too early for TOC publicity about actual timetables. I expect people will generally be using realtimetrains queries. This info will be used by National Rail as well, however it may still not be the final timetable.I cannot easily find any info for EMR May timetable on their website, I'm sure it's there somewhere! looking at National Rail I can see the last train southbound from Leicester to London is much later on weekdays at 22.52 rather than a ridiculously early 21.57 as at present which is much too early for anyone having an evening out or working the 14-22 shift and living at Mkt Harborough or Kettering so well done.
The wheel lathe at SPM is far more suited to 150s than the one at Laira where sets have to be split to use the lathe.
The information is coming from looking at Real Time Trains website or the journey planners.I cannot easily find any info for EMR May timetable on their website, I'm sure it's there somewhere! looking at National Rail I can see the last train southbound from Leicester to London is much later on weekdays at 22.52 rather than a ridiculously early 21.57 as at present which is much too early for anyone having an evening out or working the 14-22 shift and living at Mkt Harborough or Kettering so well done.
Unfortunately though one of the primary traffic flows on that line is all but obliterated by the woeful connections at Sleaford for Lincoln to Boston traffic, its less of an issue in the morning in the opposite direction but due to the bizarre pattern of trains there are some 2hr gaps in connections at Sleaford where some Joint Line services run about 40mins apart then nothing for 80mins.As may have been mentioned already, the Peterborough-Lincoln via Spalding service has a vastly superior service at last thanks to the infrastructure upgrades over the last few years. A real winner for anyone on on that route.
I expect traffic will be gained with other flows attracted to the far better timetable. Always winners & losers I suppose.Unfortunately though one of the primary traffic flows on that line is all but obliterated by the woeful connections at Sleaford for Lincoln to Boston traffic, its less of an issue in the morning in the opposite direction but due to the bizarre pattern of trains there are some 2hr gaps in connections at Sleaford where some Joint Line services run about 40mins apart then nothing for 80mins.
Are the people of Heckington and Boston really going to be interested in a 40-54min connection at Sleaford at the end of their day? If they have another choice I can see that traffic being lost.
Indeed. One of the issues here is that the improved Skegness line timetable hasn't happened, originally there was to be an early morning Boston to Newark, and I believe a late evening Doncaster (or Newark) to Boston service, but due to issues with the signalbox opening hours this hasn't happened.I expect traffic will be gained with other flows attracted to the far better timetable. Always winners & losers I suppose.
Not sure there is any other way of reversing from Letchworth to Peterborough without running all the way to Hertford (or Welwyn) to reverse?
Only place that's possible is Up Fast at Stevenage, which wouldn't be at all practical to path.
That link is only a groundframe and out of use at the moment so not a practical optionIsn't it possible to do something at Hitchin ?
There's an up > down link on the bit of the Cambridge line which then allows access to the down platform at Hitchin and the northbound lines.
Going back many years, the Huntingdon DMU could arrive or depart from either platform at Hitchin.
It seems that this service was about getting a 3-car 165 to Oxford to run into Paddington for the 0030 service. Instead, it looks like a 2-car unit will run 1P47 2305 Oxford to London Paddington and come back on the 0030 coupled to the Greenford unit.
Couple of changes for WMT.
08:38 Great Malvern - New St is diverted via Camp Hill no longer calling at University.
I suspect that the new services have been pathed around the existing freight services. It will need a fresh look at everything for a cockface service to operate.Unfortunately though one of the primary traffic flows on that line is all but obliterated by the woeful connections at Sleaford for Lincoln to Boston traffic, its less of an issue in the morning in the opposite direction but due to the bizarre pattern of trains there are some 2hr gaps in connections at Sleaford where some Joint Line services run about 40mins apart then nothing for 80mins.
I hope so, there are also issues ahead on the Robin Hood Line, the removal of a pre 9am arrival into Nottingham in favour of an 0755 Mansfield (which is long overdue) will result in a net loss of vehicles unless every train is at least 3 coaches. I don't anticipate much room on that 0840ish arrival.I suspect that the new services have been pathed around the existing freight services. It will need a fresh look at everything for a cockface service to operate.
Also worth noting is that the morning service from Lincoln to Sleaford isn't friendly for the considerable school traffic with arrivals at either 0739 (too early) or 0852 (about 20 minutes too late) compared to the current 0830. Returning in the afternoon it's also probably a bit too early at 1553 compared to the current 1614.
One to sort out in December 2021 or May 2022?
Thanks for that list. Others I have just noticed:Other changes, which appear to be new that didn’t run pre Covid-19 I’ve spotted on the Western are:
Additional train: 0753 (M-F) Paignton - London Paddington (train 1H22). This will call at Torquay, Newton Abbot, Teignmouth, Dawlish, Exeter St. Davids, Tiverton Parkway, Taunton, Weston-super-Mare, Worle, Yatton and Nailsea & Backwell before arriving into Bristol Temple Meads at 0951. After leaving Bristol Temple Meads (0954) this train will call at Bristol Parkway and then operate non-stop to London Paddington, scheduled to arrive at 1114.
Reinstated train: 1308 (M-F) Exeter St. Davids - London Paddington (train 1H40). Calls Tiverton Parkway, Taunton, Bristol Temple Meads (arr. 1419, dep. 1422), Bristol Parkway and then operates non-stop to London Paddington, scheduled to arrive at 1544.
Reinstated train: 1915 (M-F) London Paddington - Exeter St. Davids (train 1H49). Non-stop to Bristol Parkway, then calls Bristol Temple Meads (arr. 2036, dep. 2044) and Taunton only before arriving into Exeter St. Davids at 2140. Good going to do London - Exeter in not much over 2hrs.
I have marked 1H40 and 1H49 as reinstated trains: these used to run before the second lockdown. It seems that the 1Hxx trains from Bristol Temple Meads may be set for a full-on return: RealTimeTrains has 38 trains with 1Hxx headcodes in its schedules for Bristol Temple Meads for 28th May but the only 1Hxx at present is the 0453 (M-F) Bristol Temple Meads to London Paddington.
Lastly it seems that, starting with the new timetable, Exeter - Barnstaple trains will now all terminate from / start at Exeter Central instead of St. James Park with the exception of a few morning and evening journeys which will not operate between Exeter St. Davids and Exeter Central.
Dave
These 1Hxx are not showing as running in Real Time Trains if you do a Public Time search at a station - they feature as now as unadvertised services which imply they are suppressed until further notice.Thanks for that list. Others I have just noticed:
Dave
Did the half hourly fast Bristol service ever get going fully? I had two runs in the up direction. Both times I got off the up Swansea at Bristol Parkway and waited for the fast which followed about 10 minutes later. On one occasion the Swansea was delayed around Didcot so the fast overtook it at Reading. Result!I don’t think the full ‘superfast’ timetable will be running from May with the 1HXX trains every 30 minutes from Paddington to Bristol. However I think a few of them that ran before will return. All are currently showing on realtimetrains however.
Getting Cardiff back to half hourly is probably a bigger priority than Bristol 4x an hour at the moment.
Depends on what you mean by 'always' I suppose, but in the early 60s IIRC it used to be around Sept 10.It always used to be mid-May & late-September but changed to mid-December so as to come in line with Europe.
Fair enough. From the 70s as a kid I recall some holiday extras ran the length of the summer timetable until late in the month whereas the peak extras ran more or less in line with English school holidays ending in the first week of September.Depends on what you mean by 'always' I suppose, but in the early 60s IIRC it used to be around Sept 10.
AIUI all Wightlink services between PMH and Ryde are currently suspended, with tickets being accepted on Hovertravel instead. Since that's more easily reached from Portsmouth and Southsea, and Gunwharf Quays is presumably largely closed, demand to PMH is probably much reduced.One thing I have noticed is there are a lot of day time Victoria - Portsmouth services than now terminate at Portsmouth & Southsea vice Portsmouth Harbour, but there doesn’t seem to be much of a pattern to it.
