Should Elizabeth line take over the Thames Valley branches and also Romford - Upminster branch?
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
Have you ever heard of a place called Oxford? Or the wider Oxford - Cambridge Arc.
As I lived in Oxford from 1964 to 1984, actually I have.
A single regional/commuter TOC serving Thames Valley and Chilterns (and even EWR) is completely logical.
Really ? Apart from at Oxford station itself, Chiltern have nothing in common, at all, with Thames Valley services. Whereas GWR quite obviously do, and having the same operator running all services other than the Elizabeth Line into Paddington is logical.
If they run through to Worcester and are run by 800s GWR. If they are a short turns and run by Turbos these go to Chiltern. Just like lines all over the country with an IC TOC and a local one.
This is getting silly. There is no need or justification on any grounds whatsoever for two operators on the Cotswold Line.
tomuk
15 May 2010
There is nothing similar about running local\commuter services to Oxford and running local\commuter services to Aylesbury, Bicester, Oxford and Banbury? One operator at Paddington is logical but two or three operators at Euston, St Pancras, King's Cross, Liverpool Street, London Bridge and Victoria isn't?
No I don't think it is it is completely logical to have different operators for different services groups or as BR called them sectors.
Falcon1200
14 Jun 2021
Why should being a similar type of operation mean that Chiltern should take over routes with which it has minimal, if any, geographical connection ? What is far more logical is one operator running, wherever possible, services on a route, using common staffing and facilities and making operations simpler and more efficient.
What different service groups are there on the example you quoted earlier, the Oxford/Worcester line; Nearly all trains call at the same stations, the exception being the one a day each way, Monday to Friday, which stops at Finstock, Combe, etc. There is no possible reason for those trains to be hived off to a different operator.
miklcct
2 May 2021
Cricklewood
I describe the Oxford service as just a short working as the Worcester service because they call at the same stations and form a combined headway. Therefore I still call it an intercity service despite that it doesn't run intercity distance.
David Goddard
8 Aug 2011
Reading
Thames branches services will never operate through the core so there is absolutely no reason why they should be moved to be part of the Elizabeth Line Operator. "Elizabeth Line" should refer purely to the core working, not any other random branches that it happens to connect with.
If electrification was forthcoming then there could be a case for the Greenford branch to join the London Overgound family and be worked by 710s, just as the Romford to Upminster branch is (would need the Acton chord to be done as well) but thats about it.
I retain misgivings about the Elizabeth Line running through to Reading, in that for what is an inner suburban railway I think that services beyond Zone 6 should only run as far as Slough or Maidenhead, with GWR maintaining a decent semi fast service on the relief lines for Twyford, Maidenhead and Slough, and alongside that the true Thames branches to Henley, Marlow and Windsor.
Connectivity to London is great, subsuming every possible element to be part of it is not.
tomuk
15 May 2010
So they couldn't share said facilities at Oxford? They partly use the same stock. Would it not be efficient to maintain the rump GWR Turbos with the bigger Chiltern pool? Minimal geographic connection? Both serve same and adjacent counties. Major stations of Oxford, Aylebury and Bicester are within 30 miles of each other. London terminals are within a mile of each other.
The one a day return 'parlimentary service' for Finstock et al is actually four on the line as the rain needs to get to and from the depot. It is currently one two car Turbo. Not sure how running this 'odd' service formed using different stock by a different operator is hiving off it all ready is a seprate 'thing' to the IET services.
Falcon1200
14 Jun 2021
What facilities at Oxford ? Just a few carriage sidings, GWR's depot is at Reading, Chiltern's are at Wembley and Aylesbury.
Neither Bicester station is what I would call major, Aylesbury is only accessible by rail rom Oxford via a single track line and a reversal, the proximity of Marylebone and Paddington is utterly irrelevant as they are on totally different routes ! Whereas Reading, and its depot, are 27 miles from Oxford on a direct line.
What benefit would there be from running 4 trains a day by a separate operator - What would the set and crew do the rest of the time ?
tomuk
15 May 2010
GWR have a crew depot. Housing drivers who are trained to drive similar Turbos as Chiltern. Same at Paddington. Chiltern Banbury drivers operate direct services to Oxford as well as Chiltern's
Bicester had 3 million journeys pre covid I wouldn't call that minor plus there are all the new houses. Read all about it in the Oxford Mail. Paddington has no relevance? Two terminals less than a mile apart with services running to the same city 40 odd miles away running similar stock not relevant at all.
They are in effect run by a separate operator now. Different stock and crews to the 800s. They would run the other GWR Turbo services as now or it could possibly be served by Chiltern crews\equipment laying over at Oxford.
cactustwirly
10 Apr 2013
That would increase complexity as Chiltern crew would need to learn GWR 165s and the route to Moreton-in-Marsh.
It would be messy for Chiltern to maintain the 165s as they have significant differences and would have to be kept separate from the Chiltern 165/0s.
Getting the Turbos from Reading to Aylesbury for maintenance would be very complicated as access is difficult. They would need to travel up to Oxford and back down to Princes Risborough and across a single line.
Arkeeos
18 May 2022
Nottinghamshire
Would there be any benefit of converting the overground service to Watford to be part of the Elizabeth line and running that into the tunnel? You would obviously need to construct a bit of track to connect them.
David Goddard
8 Aug 2011
Reading
Thats actually not too bad a proposal, taking some of the Paddington terminators to better use. Would need some mega chord to the WLL near Scrubbs Lane but probably doable.
Be interesting then what to do between Willesden and Euston (shuttle from the bay maybe) but the distribution of the local service across the City would relieve Euston and the Northern Line in particular.
tomuk
15 May 2010
It could be Chiltern 165s or even 168s then they would only need to route learn. The competencies of the various depots would evolve over time. Ongoing training is need all the time with new starters\transfers. There is also the desire to have more services to Hanbough and to also serve the Cowley Branch which would need more resource. The exact details would need to be worked through but we are talking about a larger pooled operator of much the same services serving the same core 40 mile sector NW of London. It's likely some of the crews and managers are even neighbours now.
Reading would still be a Thames and Chiltern Depot. It quite possibly would make sense logistically and due to dissimilarities to keep the maintenance separate. Although there would be synergies in parts, heavier work and fitter knowledge. i.e. you could do heavier bogie\engine work at Reading and heavier interior work at Aylesbury or vice versa. You could move stock about on diagrammed services just like other operators.
An extension of Crossrail up the WCML was definitely looked at, but it would not have used the West London Line, but via a new curve west of Old Oak Common; and IIRC it wouldn’t have gone through Willesden Jn either.
Arkeeos
18 May 2022
Nottinghamshire
I remember there was a proposed extension to Tring early on, but im not sure what happened to that. There is some spare capacity in the central tunnel, so mind as well make the most of it.
miklcct
2 May 2021
Cricklewood
Reading is the first station call by long distance trains beyond Greater London, therefore I believe it should be the limit of where the all stations inner suburban trains go.
In fact I think the Reading Elizabeth line service should even call at all stations which it currently skips, such as West Ealing, as it currently requires two transfers from an intercity service to get there (Reading and Hayes & Harlington).
tomuk
15 May 2010
Why wouldn't stay onto Paddington and travel to West Ealing from there?
David Goddard
8 Aug 2011
Reading
Making further calls in the EL trains makes for an even longer journey for customers on these trains from Twyford and Maidenhead, who have aready seen a downgrade in service when the 345s took over.
miklcct
2 May 2021
Cricklewood
There are still semi-fast trains serving these stations. If there is no pathing issue I don't see why the stopper shouldn't call at all intermediate stations.
Similarly for the stopper from Woking which skips all stations between Surbiton and Wimbledon.
We don't see the Underground skipping stops to speed up journeys except when there is another track. Why shouldn't National Rail be the same?
Falcon1200
14 Jun 2021
Via two completely separate routes with no common points, not even at Oxford where the lines approach from opposite directions and use different platforms. BTW Oxford is 63.5 miles from Paddington.
Personally I cannot see any possible advantage, to passengers or operators, in changing the existing efficient arrangements and creating additional complexity where it is not needed.
Clearly we are never going to agree ! (but I have appreciated the debate).
It wasn't popular among WCML users because, unlike Thameslink, it would split the south WCML service between Euston and another station quite a long way away, and thus make the service rather less "turn up and go" than it is now. I believe it has long gone.
Mojo
7 Aug 2005
I suppose you could just brand the DMU’s as Elizabeth Line and then leave the drivers and operations exactly as is. I’m sure the majority of the public wouldn’t bat an eyelid. Though by that logic, why bother changing in the first place. And anyway, even though the role of GWR has changed along that stretch of the line, GWR are still operating services and have a heavy presence with fast trains going straight through using the infrastructure etc.
I think there’s definitely a case for the Greenford branch to transfer to the Overground operating on this basis, if anything the better promotion of what is a very underused service would help, although I don’t think that the branches outside of London could reasonably be transferred.
If Overground still had DMUs on the Goblin it could probably have been run by them throughout, afterall it isn’t particularly far from Willesden Jcn depot to West Ealing, but it would be such a small fleet, even if they increased the frequency.
MattRat
26 May 2021
Reading the the thread, the main problem for any transfer seems to be the lack of electrification, and therefore being force to run a microfleet. If the lines were electrified, they could be handed over easier, using the operator's own stock.
The operators own stock, in this case Crossrail fixed formation 9 car, is just far too long for any branch.
MattRat
26 May 2021
But they could get short form 345s if it was electrified, so could operate one fleet. Of course, Overground would still likely be the better option, with shorter stock it has access to, as far as I'm aware (correct me if I'm wrong).
43096
23 Nov 2015
It's not one fleet, then, is it? You go from a uniform fleet of 9-car 345s to adding a small microfleet of units to operate some branch line(s). In the case of Romford-Upminster the current situation is the most sensible: similar trains to the 345s but part of the Overground's much bigger fleet.
Let's be clear: the idea of Elizabeth line taking over assorted branch lines isn't a good one. It's not sensible and would create more problems than those it purports to solve.
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
Where do you propose that the Elizabeth Line keep and service a bespoke fleet of five diesel units to operate the Thames branches?
Have you not noticed that the timing of the branch line trains matches the times of the GWR services at Twyford, Maidenhead and Slough, rather than the Elizabeth Line ones?
From an operational and practical perspective, no.
As soon as a Speculative idea is created, I notice you’re immediately there to shut it down cynically.
There’s no reason why GWR couldn’t sub-lease Turbos to XR to be used on the Thames branches and base them at Reading. The GWR services you mention are also replaced by both extra Elizabeth line services and limited stop Didcot services during peaks, as I’m sure you know. There was also much (admittedly speculative) discussion about Didcots being truncated at Reading with the Paddington paths being transferred to allow for more Elizabeth line services to run.
I don’t know about anyone else, but I’m getting a little fed up with every time something is suggested, you come along and shut it down. This is a Speculative sub-forum anyway. If this was Allocations, Diagrams and Timetables, Traction & Rolling Stock, or another formal sub-forum, I would understand your hesitation to allow such ideas to be discussed.
That doesn’t, however, mean I agree with the OP; I believe the branches are better off with GWR all the while the Didcot service continues to operate.
Wolfie
17 Aug 2010
I appreciate that this is a Speculative thread. Even so surely there needs to be some actual advantage to a proposal other than because it would be neat or because it can be done!
Not quite my intention. What I really want to see is more explanation as to why it is a good idea. To be fair to the OP they gave a fairly detailed argument, but overlooked the practicalities.
I very much welcome a good idea. It would be great to have debate about very practical ideas based on workable concepts where the consequences are thought through.
There are nearly sixty posts in this thread. One person can't shut down conversation.
There isn't but what does it offer passengers, how does it build custom, does it have pitfalls, does it cost money for money's sake, does it make things better for passengers, does it make the railway better from an operational point of view?
cactustwirly
10 Apr 2013
What benefit does that bring, except make travel inconvenient for passengers and increase costs for the railway.
Why should TfL have responsibility for services in rural Buckinghamshire and Oxfordshire?
