TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
37052 xb mr
6 Dec 2023
Stockport
Tomorrow's plan-
HD01 as above 1V91 etc
HD02 stabled at Crewe, 67010 return to it
HD03 1W13 1V39 1W96
HD04 ECS to ETD for tyre turning (possibly return to ATC in the evening)
HD05 as above 1V31 etc
HD06 1W11 1V37 1W59 1V50
HD07 as above 1v33 start
Thanks
MP393
28 Jun 2021
North West
Tomorrow's plan-
HD03 1W13 1V39 1W96
Added the others to my post for completeness thanks as always!
sd0733
7 Nov 2012
1V31 swapped for a unit last minute this morning, 1V31/1W55/1V42/1W63 now showing 197104.
Hd05 won't be back tomorrow either due to its faults, HD01 also planned under repair at Crewe tomorrow with HD02/03/04(if back from tyre turn)/06/07 on the 5 diagrams.
03 then finishes in Crewe fir it's exam.
Jacob Porrett
28 Jan 2022
Telford
Today at Crewe depot: (3/4/25)
67008 connected to HD01
67016 connected to HD05
67013 connected to HD04
66029 light engine.
sd0733
7 Nov 2012
Crewe is turning into a bit of a graveyard for Mk4 rakes with HD01/04/05 all under repair today.
01 has been pulled and will now go on exam for a couple of days, one of 04 or 05 ( with 67029 vice 016) is hoped to go out tomorrow.
HD03 is planned to end there tomorrow night then has exam over the weekend.
The poor reliability over the last couple of weeks has knocked sets out of place so bunching up of exams has occurred.
37052 xb mr
6 Dec 2023
Stockport
Thanks
sd0733
7 Nov 2012
67025 is now back available and at ATC swapping places with 67008 which has gone to ETD for repairs.
Tonight, HD03 and HD04 are planned to swap locos with 67013 going onto HD03 and 67022 going onto HD04.
Tomorrow should see 67010+HD02 and 67029+HD05 out of Canton with 67013+HD03 and 67017+HD06 out of Crewe.
Sunday should see 67016+HD01 on the Crewe diagram with the Canton diagram expected as a unit.
37052 xb mr
6 Dec 2023
Stockport
Thank you
BillStampy
6 Jan 2024
Llanharan
1Z99 is now en-route to Pyle to pick it up, is this the first time the rescue operation has been undertaken west of Cardiff?
sd0733
7 Nov 2012
Yes believe it is. Loss of air pressure on the set.
To balance things for tomorrow, 18:37 Cardiff to Manchester and 22:30 back to Crewe are allocated to 67017+HD06.
BillStampy
6 Jan 2024
Llanharan
Supposing they'll fix HD01 overnight to get it out for either 1W11/1W13?
sd0733
7 Nov 2012
Believe the plan is for it to go out on w11 if fixed, if it's not it can also pick up the second half of the diagram but if it doesn't make it at all it doesn't overload Canton.
HD04 is pencilled in for W13.
37052 xb mr
6 Dec 2023
Stockport
Monday 7th April
1W11 - 197119
1W13 - 67029 set 5
1V91 - 67020 set 7
1V31 - 67022 set 4
1V33 - 67017 set 6
Cardiff - 67016 set 1, Air leak
Crewe - 67010 set 2
Crewe - 67013 set 3
robert thomas
2 Jun 2019
Neath
HD01 terminating at Cardiff Central, stuck at Pyle.
I was on this. The first time we halted was at Water Street Junction where the line into Margam Hump yard used to diverge. The engine appeared to shut down and restart and after 10 minutes or so we continued until the brakes were applied for Pyle and we came to an abrupt halt with only the first coach in the platform. Further attempts to move failed and the guard eventually opened the doors on the first coach and passengers were sent over the bridge to pick up the following train running wrong line.
