TfW - Trainee Conductors - Various Locations (31/03/22)
At88
16 Dec 2023
Cardiff
Not likely to show up. There is a list of stuff you can't take. Take the prescription with you and be honest. You won't fail the medical, even if it's one you can't take you'll be sent to the Dr to get a note and change it to something you can take.
Where it would become an issue is when you're working, had an incident then you told them about it. So be up front at medical and like I said worst case scenario is you go back to Dr tell them you're starting a safety critical role and they can advise from there.
That’s brilliant. Thank you so much! It’s not the strongest painkiller in the world, but I think I’ve just got some pre-new job nerves. I should add, this is for the conductor role.
cw11
9 Nov 2023
North
Happy new year all.
I’m yet to hear back from TFW following the TCT that I done 08.12.23. I have sent an email to recruitment to and had no updates. Is it usually this long?
Thank you
mugatneysface
31 Jul 2023
Merthyr Tydfil
Happy new year all.
Thank you
Yeah they don't rush these things. I completed mine on 24/8 last year and didn't hear anything until I emailed them about a month later but even when I emailed them it was a week or so before I heard back. Hang on in there and you'll hear soon. From my experience with TFW no news is good news.
cw11
9 Nov 2023
North
Thanks for that. I had a slight typo there, it was 08.11.23 i completed it. I knew it would be a timely process but the not knowing if Ive passed to the next stage is mind boggling.
dave360
3 Jan 2024
Wales
With the aptitude tests sometimes if you fail they will not email you back
cw11
9 Nov 2023
North
I did have a email to apologise for the delay as the results had not been processed when I initially chased it up on the 7th of December but nothing following the email I have sent recently.
I have also signed into my online application and it states the progress as conductor online testing which doesn’t give any indicator of whether I’ve failed or not.
Cross fingers is due to playing catch up following the holidays.
Thank you for the replies :)
Louishunt
5 Jul 2023
Llandudno
Hi guys, I’ve got my SCAAT test to do within the next week. Can anyone advise what the test consists of? And any practice material available? Thanks
Tevion539
23 Apr 2020
The Milkyway
It's crossing off shapes. You have to ensure you're consistent and correct. Don't worry about finishing the entire page. Just go at a steady pace and try and cross off as many as possible.
Three sections, three pages each.
Say in section one you're asked to cross off "x", you work your way from left to right, one line at a time crossing off "x" every time you see it.
Section two will usually be the same shape, but read the instructions carefully, plus another shape.
Section three will be another shape plus the shape that's on the start of your current line... For example...
[] X () ( ) / ......
X ( ( )( () \
In this example:
Line one, you'd cross off [] (plus the shape stated in instructions)
Line two, x (plus the shape stated in instructions)
If this is done online, you just click the shape to cross it off. Ensure you click the shape that's the same orientation. The test is there to see that you're able to concentrate when faced with a monotonous task. As for practicing? I'm not sure if any resources apart from the practice tests provided by the OPC.
Hope this helps.
mugatneysface
31 Jul 2023
Merthyr Tydfil
https://metodorf.com/tests/bourdon_test.php
When I did my SCAAT test I used this to practise. Don't get me wrong it's not the same shapes you'll see in the test for TFW but it's a good way to get your eyes trained for doing the test. Hope this helps
12 Aug 2020
Shropshire
My friend has his conductor assessment day coming up. Could anyone give me any info either on here or via DM on what to expect and research etc please?
Any help would be appreciated.
I'm not back at work till Wednesday so will be able to ask the guards at my depot then but if I could give him some info now that would be great.
Thanks all.
Tevion539
23 Apr 2020
The Milkyway
Thanks all.
Not much is known about what happens at these assessments. Unless someone who's been through it is able to answer. Which no one has, so far. All I know is, there's a group exercise. You have to communicate well. That's about all I know of it.
12 Aug 2020
Shropshire
Thank you. I'll ask around tomorrow and if I can add any info on here for other people's assessments then I will.
Probably won't be till Thursday though as I'm on lates.
mugatneysface
31 Jul 2023
Merthyr Tydfil
Strange question I know but I was wondering if anyone knew what the deal would be with availability whilst I'm route learning. I'm due to start in mid April but I've got 2 days (afternoons) that month that I can't work. Any advice?
craigybagel
25 Oct 2012
Speak to your manager. They're usually pretty flexible and you should be able to fit your route learning around your availability within reason.
Tevion539
23 Apr 2020
The Milkyway
To add to Craig's post - some managers are so flexible that they allow you to choose your own hours when route learning, so long as you make up your 35 per week. Just make sure you only take your route exams when you are absolutely ready for it.
Trainbunny
5 Mar 2023
Wales
Hi everyone
I've been invited to do the RAAT test, just wondering if you have a set time to read the passage then it disappears, or do you have the passage available when answering the questions?
Tevion539
23 Apr 2020
The Milkyway
Hi everyone
If memory serves right, there is a set time. However. I wouldn't worry about the time and just simply focus on answering the questions to the best of your abilities. If you rush and answer all the questions and get enough wrong you won't go through. If you answer (say, 85%*) and get them right you'll be in a better position. *The pass mark is unknown, but it's better to be accurate and consistent than to rush and be wrong.
SuperLuke2334
23 Oct 2021
Hereford
Hi all,
Thinking of applying for the Trainee Conductor position currently available at Cardiff Mainline.
I'm currently living in Hereford, however there is the option of 'Willing to relocate'... would this affect my application at all? I'd hope not!
Has anyone got any advice for what I could put into my answers in the questions?
Thanks!
Tevion539
23 Apr 2020
The Milkyway
Hi all,
Thanks!
Hi Luke,
Willing to relocate hasn't usually been an option before. They usually say no to anyone applying outside of being an hour away from their chosen depot... This may have changed and if he option is now available, apply. Give it your best shot and if it's good enough I don't see why they would say no. When it comes to the application questions, you will need to make sure you hit the word count. Not doing so will result in your application not being progressed. You have to be safety minded, punctual and then committed to customer service. But I must stress, safety is paramount - theres no good putting customer service ahead of your safety critical duties if someone gets injured. Try and give as much detail and sell yourself in the questions...
Without knowing you or your experience, it's difficult to tell you exactly what to put in there. It's individual to you, and you definitely shouldn't fabricate any answers.
SuperLuke2334
23 Oct 2021
Hereford
Hi Luke,
Thanks for your answer.
Re the word count, is that advertised on the application?
Signal_Box
25 Dec 2021
No, my daughter has applied she didn’t get a word count. But I assume if your over the system will tell you.
Regards relocation - I think it’s probably dawned that a 60 minute rule is significantly reducing the pool of candidates, it can take 60+ minutes to get into Cardiff from the likes of Newport sometimes only 14 miles away.
Tevion539
23 Apr 2020
The Milkyway
Unless it's changed - the questions at the end of the application had a min 250 and max 500 words. I asked a question about this, and was told applications get rejected if people don't meet them. Again, it could've changed. But if there's a word limit specified on questions within the application (i.e. why do you want to work for us?) I'd recommend keeping to them.
I used MS Word to type out my answers and checked for typos and spelling errors. There's also websites out there that you can paste your replies into to check your count.
