Supercoss
- Joined
- 5 Jun 2016
- Messages
- 301
I was fortunate to get one of the Redhill to Horsham shuttles.They put in Redhill to Horsham shuttles which worked well for the first two hours but then fell apart and didn't recover through to end of service. Hopefully the Bognor trains stopped additionally although that's hit and miss in my experience. I'd never risk waiting at Littlehaven during disruption.
Why can 700s not run in multiple but 717s can ? Aren't they pretty much the same train ? Also could a 717 rescue a 700 ? or Vice Versa ?As 700s can't run in multiple and drivers are not trained to couple or uncouple them ( as not required in ' normal' operation ) a driver manager or fitter is required to attend.
A "push out" has been done a few times with unit mechanically coupled but not electrically ( electrical connection latched back) and ' rescue ' air pipe connected.View attachment 112548View attachment 112549
700s are 8 or 12 coach trains. So a minimum of 16 coaches if two are coupled together.Why can 700s not run in multiple but 717s can ? Aren't they pretty much the same train ? Also could a 717 rescue a 700 ? or Vice Versa ?
The whole core is indeed Bi-Directional (from Blackfriars to Canal Tunnel Junction and just south of Kentish Town), and there are a number of crossovers within the core to permit rerouting, which were made use of last night to release the trapped trains. See https://www.opentraintimes.com/maps/signalling/tlk_coreAs the core is, well, core to Thameslink, and as the above post intimates that it's bidirectional
The OHLE in this instance is technically not an Overhead Line but an Overhead Rigid Conductor Bar for each track. Each is mounted independently to the tunnel roof so the chance of one bringing down the other is very small. The OLE didn't fail, it was damaged by a pan that was never meant to be up.could the OHLE be made independent over each line so that if it fails over one track, the other is still useable. Just a thought.
So if the OH Rigid Bar wasn't damaged in one direction, why was the core section totally closed? Or have I missed something?The whole core is indeed Bi-Directional (from Blackfriars to Canal Tunnel Junction and just south of Kentish Town), and there are a number of crossovers within the core to permit rerouting, which were made use of last night to release the trapped trains. See https://www.opentraintimes.com/maps/signalling/tlk_core
They certainly can run as pairs of units and 24 car 700s have been tested through the core. Although that was to confirm that their intended recovery function would work, where one unit was pushing/pulling the other, especially up the 1:29 grades in the core, I presume that the consist could work fully powered if the fault was in the leading cab of one. How the signalling could cope with a 480m long train would be interesting as sections are very short in much of the core. The OLE would be OK with a theoretical 10MW load, but I doubt the 3rd rail would be happy with a 6MW one.Very true, that's a valid operational reason they do not run in multiple. But in theory could they technically run as multiples (probably with a couple of pans down to reduce OLE burden) should the need ever arise ?
Or is 700-700 coupling for rescue purposes only ?
Initially the train failed across both lines. Later both platforms at Blackfriars were blocked to allow the pantograph to be removed safely.So if the OH Rigid Bar wasn't damaged in one direction, why was the core section totally closed? Or have I missed something?
It's been talked about as I believe you can't get a 12-car in there and as you say it requires an awkward move to get out of them. However abolishing sidings that presumably had a reason to remain because the driver put the pan up when they shouldn't seems a tad extreme. The other stabling options would presumably be Hornsey or Cricklewood, maybe with 1 train left at Herne Hill turnback.Getting rid of Smithfield Sidings might be the answer, as its value appears marginal at best. There seems to be a bit of "wrong line running" (yes, I know it's bidirectional but access/egress looks convoluted) which must reduce core capacity when trains turnback/stable there.
As I understand it, the pan was raised in error. 5V55 was planned to go to Blackfriars. The schedules is labelled as VSTP in RTT, indicating it was a late-notice alteration to the plan. This may have increased the chance of the driver making the mistake.I'm trying to get my head around as to why the pan would be raised anyway. Was the unit reversing at City Thameslink to go north? But then it wouldn't have blocked both lines. A tad confused.
Definitely a challenging route to drive on though and as mentioned it's nuts that smithfield is dc only but there must not be clearance for AC wires there...It is odd thats for sure, could have been turning back at city and then told otherwise and had to go SB and forgot to change it back, as a driver on that route I must admit I'm not sure how it's happened if its definitely come out the sidings as if you were going straight through you'd just chuck it in dc mode until you got to blackfriars to make sure , well I would anyway, not entirely necessary but belts and braces and all that.
Either way the driver will be feeling like dirt so let's not forget them in all this, mistakes happen and lessons will hopefully be learnt .
Northbound changeover regularly takes place at City TL, Southbound at Farringdon. If the changeover should fail, this allows the driver to contact the signaller and arrange for trains to be held, then advance to the next station to change direction and return to the system that works.I'm not all that clear about current-day operations, but back in the day, I thought the changeover from DC to AC (and vice versa) always took place whilst the unit was stationary at Farringdon. Are there now different locations where this can happen; not just at Farringdon? Are Smithfield Sdgs equipped with both 3rd rail and OHLE?
Cheers; thanks. Didn't know that.Northbound changeover regularly takes place at City TL, Southbound at Farringdon. If the changeover should fail, this allows the driver to contact the signaller and arrange for trains to be held, then advance to the next station to change direction and return to the system that works.
No, they are 3rd rail only. So a driver heading north would have to leave on 3rd rail then change to OLE in the Platform at City TL. A driver heading south would be on 3rd rail all the way out.Are Smithfield Sdgs equipped with both 3rd rail and OHLE?
This was discussed upthread, although I'm not sure what the conclusion was! I think it only takes power from one source but can run with both pickups extended.PS Can a 700 run on 3rd rail with the pan up? Surely there'd be electrical/mechanical interlocking to prevent that?
The shoes are not retractable on 700s which might be why there's confusion, unlike a 319 they are not active as such unless in dc modeNo, they are 3rd rail only. So a driver heading north would have to leave on 3rd rail then change to OLE in the Platform at City TL. A driver heading south would be on 3rd rail all the way out.
It shouldn't have put it up so its a bit strange if its come out the sidings and gone southThanks again. But if heading north, the unit wouldn't have had to cross to the southbound line. So presumably (in this case) the unit was heading south so wouldn't have needed to raise the pan at all. Sorry for asking the obvious questions...
I may well be in the minority but I see no reason for changes to the infrastructure when the fault, unless something exceptional took place with the unit itself, is solely down to driver error, if you sign the route then you must be fully aware of the requirements in that area, back along I used to take 325s on the Willesden - Tonbridge route, my route knowledge along with lineside notices made me fully aware of the impending AC to DC changeover, nothing else, especially infrastructure expense, was required
To a point. But as "The Core" is such a vital part of Thameslink, I'd have thought they'd need a belt and braces approach to ensure things didn't go wrong, even if there were a driver's error. Think of all the palaver at Cardiff Central to prevent an IET heading west with its pan up, with balises to ensure drivers have to use diesel power (with pan down) to access the electrically-wired Brickyard Sdgs.I may well be in the minority but I see no reason for changes to the infrastructure when the fault, unless something exceptional took place with the unit itself, is solely down to driver error, if you sign the route then you must be fully aware of the requirements in that area, back along I used to take 325s on the Willesden - Tonbridge route, my route knowledge along with lineside notices made me fully aware of the impending AC to DC changeover, nothing else, especially infrastructure expense, was required
The cost ratio will be insanely high. If you counted the number of trains doing a changeover, taking units out the Sidings, and generally making these moves on a daily basis. The number of incidents is a teeny tiny fraction. How much are you prepared to pay for it ?Surely if there are sensible, affordable, changes that can be made to the infrastructure, which would reduce the impact of a driver error, they should be implemented.
In many industries, including much of the rail industry, technology is used to prevent people from making mistakes. It seems in this case some people just want to blame the person rather than asking "why didn't the technology prevent the driver from having the opportunity to make a mistake" or "why didn't the technology reduce the consequences of the driver making a mistake".
