And me too. Thanks again, its been compulsive reading/viewing.
me too! I have followed the thread almost every day!
It is a pity we don't have similar coverage of GW electrification, although that seems to be mostly bad news!
2. On a still-to-be-snagged note I've been told that what I termed Passes 5 & 6 in last night's test runs (please see the Photos in Series 3306) exposed some work still to be done with signal LL1577, which is the one 'in the wrong direction' at Huyton. The planned shunt move didn't go smoothly, and the signal had to be passed at danger, as the signaller couldn't clear it.
Dave
Surprised that despite the testing and a nationwide DMU shortage that EMUs won't be used in regular service between Warrington Bank Quay and Liverpool Lime Street. :cry:
Initially no, but plan is to use electric units this year.
Five sets of 319's outside in the sun at Allerton this morning, all in Northern livery.
I'm delighted that Bill from Huyton has followed his film of a 319 belting through Huyton the other evening with a load of photos he took at Roby, Huyton and Huyton Quarry from March to July 2014.
I have added 47 of them to Bill's album here:
https://www.flickr.com/photos/127646831@N03/sets/72157648707438634/
I have also added them to the Combined Volume in their correct chronological places. That means you may find them easier to find in Bill's album, where they constitute 47 out of 48 items, rather than hunting for them than spread among the 2000 plus items in the CV. The photos' numbers are the same in both albums.
The Combined Volume is here:
https://www.flickr.com/photos/127646831@N03/sets/72157648494725811/
Thank you Bill
Paul Gaskell and I went for a half day road tour of the Wigan Branch north of St Helens earlier today.
The good news is that wires are now attached to Carr Mill Viaduct's masts by permanent metalwork, with the exception of one wire to the more southerly mast using the sort of purple temporary strap and pulley we have seen so often.
It is impossible to get nearer than telephoto and binoculars range of Springs Branch Junction. But using that equipment plus Mk 1 eyeballs we could see that most if not all wires are up to within a mast or two of the junction, but there are no wires joining the last few yards to the WCML.
Elsewhere, eg near the Haresfinch estate in northern St Helens there is a light sprinkling of purple strapping fixings here and there. Most of the branch seems to be fully wired.
There were a heck of a lot of Orangemen near the Ince Moss Chord, but they appeared to be using the car park as a rendezvous and lunch break area. We spoke to one near Taylors Lane, who said he and his colleagues were 'de-veging'.
We wondered if this meant removing the lettuce from their sandwiches, but decided it meant cutting down trees.
Photos later
I was delighted that Paul and I went on a joint jaunt.
I have put Paul's photos in his album here:
https://www.flickr.com/photos/127646831@N03/sets/72157649792560381/
and both our shots in the Combined Volume here:
Thank you Paul.
Dave,
Thanks for the time and effort taken into sorting all those photos into some sort of order.
In answer to your question... " Are you sure?" on 0898e Huyton. Yes!
Regards,
Bill
My text was over-hasty and too cryptic. I've tweaked it now so it might make more sense.
Thanks for pointing it out.
Dave
Until their
Thank you Bill
Photos later
Thank you Paul.
Great pics Dave. The view in 3322l is interesting. It shows the compact isolator section that was introduced in the '60s. The originals had composite insulator sections of contact wire (the bits between the pairs of vertical sticks). These insulators were alternate beads of PTFE and glass that prevented water running along the surface. I wonder what their construction is now. It seems that they are supported by glass fibre bars.
They were designed to allow use on lines up to 100mph. Previous designs either occupied upwards of 200m with up to 60m dead zone (looking like double wire-end transitions) or there were short sections where several heavy metal framed insulators were used and limited speeds to below 60mph. These slower types are now sometimes used on crossovers.
I would expect NR need a possession and isolation of the WCML as well as a possession of the Wigan to Huyton route to finish off.
Does anyone know if there are any major possessions of the WCML coming up shortly in this area?
Doesn't need any major possesions to connect to the WCML, can and usually be done on a normal Saturday night possession. I would suspect that all that is needed is the actual crossovers wired probably around 200m or so of wiring.
What usually happens is the branch line is under posession first (prob an hour or 2 before the WCML) allowing staff and machines to get into place at the marker boards just before the WCML, then once the WCML is taken and isolated they can get straight on with the work
The 319s will not be out in passenger service tomorrow, as I believe the ORR haven't signed off on them being used yet. It's looking like it will be later in the week before there are out.
Sad to say I've also heard from an authoritative source that 319s won't start on Monday. S/he didn't know the reason.
Heard off a guard on a train from Manchester tonight that electric services are now likely to start next Thursday.
Does it matter when they start this week or whatever soon, as they be operating everyday of the year and then you can pick whatever train you wish to travel on, as one Class 319/3 will be the same as the next one! The first journey wont be much different to the second, third and so on journey. Sorry I just don't get the fuss about when they start - Class 319's (albeit ECS) have already operated on the line so it is now history. Sorry members.
