Hopefully it will make life very difficult for them! The only advantage I see to these skip-stop services.
I thought so - that would be one reason for going to a skip-stop pattern.
I can't recall Arriva having anything to do with Vivarail and the 230s.
There's no reason Northern can't use 185s released from TPE, but these can't be substitutes for the specified new build (with the caveats in the last few posts).
Without sounding dense, I notice people are obsessed with 442's can someone enlighten me as to what I'm missing?
Someone from Arriva did go to Vivarail to look at D-Trains on behalf of ATW.
The ITT did rule out including them in the December 17 or December 19 train plans but nothing is ruled if in the future they decide they need trains for extra capacity or new services.
TransPennine Express services to/from Windermere will be operated instead by Northern from the start of the new franchise
a minimum of 4 trains per day in each direction between Windermere and Manchester Airport (compared to no more than 2 today). These will be Northern Connect services, operated by new electric trains (once the Windermere branch has been electrified and sufficient new trains delivered)
todays level of service between Windermere and Oxenholme will also be maintained, again to be operated by electric trains once electrified.
Does Rotherham Central get any improvements in services? New destinations etc? (Either with TPE or northern)
Apologies. My phones done a wobbly and posted this twice. Not sure how I delete one of them! Apologies.
Well, given the lead time for new stock (which is a given with electrification coming) 185s wouldn't be available within that period anyway..
Either way, it's obvious to everyone (on here at least) that the 185 fleet is insufficient for the North TPE route, and with electrification coming sooner or later some of the units will become surplus.TPE seem to have an ambitious plan for getting the new trains in place ASAP but the ones produced initially won't replace 185s but will provide extra capacity and it might be TPE aim to release the 350/4s first.
In enthusiast circles the 442s are held in high regard, and given that they were specified as an option in the ITT for TPE, it isn't surprising that they were expected (or hoped) to play a part at least in the medium-term. Even following the announcement of the new franchise people are still looking for any sign that they may still play a part...A number of people on this forum think there is no need to order new diesel powered stock as electrification can replace diesel stock and provide additional capacity. However, electrification is a slow and expensive process and we need a lot of extra capacity as well as needing new trains to allow life-expired trains to be withdrawn.
Where the 442s come in is there electrical equipment is getting worn out but the carriages are still in usable condition and they are also quite big so potentially they could do a job somewhere. However, some people have doubts about whether they would be suitable for TPE as the dwell times may be longer and acceleration may be slower than using multiple units.
The story is that First were negotiating with the SRA on the financial terms of the TPE contract, with the SRA wanting more payment/less subsidy from First. First knew that the only other company in the running was Connex. Dean Finch, who was leading the First negotiations, apparently replied "Fine, and which of you is going to tell the minister you're going with Connex?" At that point the SRA position collapsed and the deal was done.There were reports last time Connex originally put in a better bid than First/Kelios for TPE but the SRA decided to give First/Kelios some 'constructive feedback' on their bid to make it better (possibly because of Connex screwing up South Central) and then they eventually won but the bidding process is different now.
They are great lads in West Allerton
It helps that the class 442 has always been quite popular due to its unique appearance.
The Long Term Passenger Rolling Stock Strategy for the Rail Industry, 3rd Edition, Feb 2015, said:Why can't they be 172s with a different engine that does meet the spec? An engine change doesn't require a class number change.
Body work and crash structure wise, if they can still build a 387, they should still be able to build a 172?
The document was produced jointly by the Rail Delivery Group (including an Arriva representative) and all three ROSCOs, and incorporated input from the train builders.It is probably unlikely that a business case can be made at present to fit a Stage IIIB
compliant diesel engine (or engines) to any of the existing British DMU types. The D-Train
project being developed by Vivarail proposes to examine the feasibility, reliability and
business case of fitting pairs of smaller Stage IIIB compliant automotive diesel engines
beneath former LUL vehicles.
Doesn't ever usually happen on day 1 like that. Route swaps and stuff usually coincide with a main timetable change. It has already been said that the Barton service will not transfer to EMT until that franchise is re-let in 2017.
The Hitachi bi-modes make room for the Stage IIIB engines by having raised floors in 26m long carriages.
They are coming off the Gatwick Express services in 2016 and have no announced destination, so there is massive speculation about where they are headed.
It helps that the class has always been quite popular due to its unique appearance.
Has Northern lost its franchise?
No, Northern Rail has not lost its franchise...
I believe a lot of senior staff are staying on, and the branding will be staying pretty much the same, so they are calling it a continuation of the current company rather than a replacement.
The only two post-privatisation companies that the Chairman of Vivarail has worked for are Chiltern and LOROL, both part of Arriva. I'd say he might have some links.
I'm not sure what the deal with the Plastic Pigs is either.
I'm still laughing at the fact whoever drafted the ITT put it in though, given enthusiasts' obsession with the things. Obviously a sense of humour. I wonder who on here did it?
It also had some pretty unique features for an EMU built in the late 80s: a proper buffet, compartment first class, a 'proper' guards van, powered interior doors, a phone box... Though none of these unique features survived their spell with GatEx.
Agree that the message is very different to what is normally posted when a franchise is lost, normally there is a statement about how they 'would have been better' rather than the logo of the new company!
